Doe's anyone else have front end chatter on CRF250r?
  • daluk
    by daluk » Sat Mar 03, 2012 10:41 am
    Hi Guys,
    Out on the bike today (for the first time) and when loading up the front end going into a burm (quite quick) the front end had loads of chatter!
    Is this just a matter of setting it up right?
    Cheers,
    Dal
    DarkCRF
    by DarkCRF » Sat Mar 03, 2012 10:53 am
    If you have one, add some click on the Steering damper
    Bike model and year ?
  • daluk
    by daluk » Sat Mar 03, 2012 11:05 am
    its an 08 crf250r. Its more the forks bouncing up and down. This only happened in 1 turn which is down hill into a burm on the brakes.
    DarkCRF
    by DarkCRF » Sat Mar 03, 2012 11:15 am
    Did you try to fix it with the clicker ?
  • daluk
    by daluk » Sat Mar 03, 2012 11:23 am
    no, I wouldnt know where to start! :oops:
    DarkCRF
    by DarkCRF » Sat Mar 03, 2012 11:41 am
    First of all, set your sag. Something between 100 and 105 mm.
    Find a place where the trouble is evident and remove 3 click of compression. Try it again, if you see some improvement continu this way until you feel you don't help it anymore. At this point fine tune it with 1 click up or down at time.
    If you didn't see improvement in the first step, try by come back in the original position and add 3 more click. Continu like a explain below.
    After it, do the same thing with your rebound clicker.
    When you finish to adjust the reboud, reajust the compression the same way from the beginning
  • daluk
    by daluk » Sat Mar 03, 2012 11:46 am
    Thanks for the advice...!!!
    I will give it a go and let you know!.. Great bike though!
    Chopped in my 125 smoker and its the best thing I could have done. People say smokers are more fun??!! I had more fun today than I ever had on the 2T.
    Thanks again for your help!
    Dal
