Floating valve seal???????
  • LRussoPhoto
    by LRussoPhoto » Wed Feb 22, 2012 8:23 am
    I have a 08 crf150r and I am having a high idle problem. I have tried numerous things, different pilot jet sizes, clean out carb multiple times, mixture screw adjustments, checking for air leaks, checking timing, checking valve clearances and nothing seems to fix the problem. I see that the store here sells the floating valve seal separately and says it fits fcr carbs but the plate on the 150 looks smaller then the one on my 450. Does the online store sell the seal for the fcr on the 150r?
    by crfsonly » Wed Feb 22, 2012 12:22 pm
    welcome to CRF's Only. yes, the 150R floating valve seal is smaller than the one we offer for the 250/450. i can get this for you but it's a whooping $16.98! let me know.
    again, welcome.
  • LRussoPhoto
    by LRussoPhoto » Wed Feb 22, 2012 12:51 pm
    Yes please, let me know how to make a payment.
    by crfsonly » Wed Feb 22, 2012 12:56 pm
    ok...it will take a few days to get in stock. once in stock i'll add to our catalog and you'll be able to order it online.
    i'll post at that time the link to it in the catalog.
  • LRussoPhoto
    by LRussoPhoto » Wed Feb 22, 2012 1:20 pm
    ok thanks
    by crfsonly » Wed Feb 22, 2012 2:39 pm
    in the mean time...if you have removed the slide check to make sure the floating valve plate is correctly oriented.
    by crfsonly » Fri Feb 24, 2012 10:42 am
    we have the floating valve seal for the CRF150R in stock now. here's a link:
    http://www.crfsonly.com/catalog/product ... ts_id/4514
  • LRussoPhoto
    by LRussoPhoto » Fri Feb 24, 2012 11:01 am
    Ordered, thanks!!!!!
    by crfsonly » Fri Feb 24, 2012 2:56 pm
    you're welcome! thank you!
  • LRussoPhoto
    by LRussoPhoto » Thu Mar 01, 2012 10:49 am
    Got the seal today, unfortunately it didn't fix the problem. Any ideas?
    by crfsonly » Thu Mar 01, 2012 1:33 pm
    did you make sure to install the seal and plate in the correct orientation? this is absolutely critical.
