XR-50 runs...then not
  • kevpilot
    by kevpilot » Mon Dec 19, 2011 10:34 am
    My '02 XR-50 starts, idles and warms up fine, runs in first gear with not too much throttle demand...... but when I add more throttle and shift to another gear, the bikes stutters and chugs as if not getting enough fuel.
    We just completed an oil change, air filter cleaning, and carb soaking and cleaning to remove old gas and gunk. Everything mentioned is clean now.....so.......any thoughts as to causes?
    I thought fuel petcock, but I just drained the entire fuel tank using the fuel line attached to that and the tank drained fine.
    Thanks
    by crfsonly » Mon Dec 19, 2011 10:48 am
    check the float in the carb.
  • kevpilot
    by kevpilot » Mon Dec 19, 2011 6:22 pm
    okay...pulled the carb off AGAIN! Took it apart. The float floats. Soaked everything in carb cleaner and blew out all the orifices I could find. Back on the bike tomorrow. In theory all should work besides a little idle adjustment......right??
    Am I missing something in this simple little carb?
    Thanks
    by crfsonly » Mon Dec 19, 2011 6:26 pm
    if the float is sticking or the level is too low this could explain your situation. so make sure it's set up correctly and working as it should. if it is not the carb then the next place to look is electrical.
  • kevpilot
    by kevpilot » Mon Dec 19, 2011 6:34 pm
    thanks
  • kevpilot
    by kevpilot » Wed Dec 21, 2011 3:01 pm
    I got the carb all cleaned and put back together. Before installing the carb I tried to removed the exhaust tip....and low and behold......it wouldn't budge! I carefully chiseled it off and it was a mess! Sanded and soaked the spark arrestor to get it cleaned and clear. Removed the exhaust pipe and tapped it on the garage floor to get as much rust and chunky crap as I could out of the pipe. Re-installed the pipe and while the tip was soaking I re-installed the carb and took the bike for a quick run. It ran great! Through all three gears and plenty of throttle.
    Maybe the blocked up exhaust? Maybe I cleaned the crap out of the carb? Maybe both?
    by crfsonly » Wed Dec 21, 2011 3:08 pm
    good to hear it's resolved...yeah could be one or the other or both. good news is it rips now!
