Sprocket suggestions...
  • storm720
    by storm720 » Sun Nov 20, 2011 1:28 am
    I need some recommendations for sprocket selection for a 2007 CRF150F. It has Pipe, jetting, air box mod. I've read the 420 set up is prime, but what about tooth count in the rear compared to stock? Thanks.
    by crfsonly » Sun Nov 20, 2011 4:41 pm
    use are gearing/rpm/speed calculator found here:
    http://crfsonly.com/howto/gearing/motor ... ulator.php
    it will help you determine what is the best final drive gearing for your needs.
