250r transmission
  • app1
    250r transmission
    by app1 » Tue Nov 15, 2011 6:24 pm
    i recently went to put my transmission together and the mainshaft shifting fork sits fine in the drum, but i cant get the countershaft fork to engage the drum when the alignment pin is in. any thoughts?
    by crfsonly » Tue Nov 15, 2011 10:29 pm
    couple of questions. 1. are you using the manual to put the trans back together? 2. what was the reason for tearing into the trans?
  • app1
    by app1 » Wed Nov 16, 2011 8:23 am
    i do have a manual for it. im using a Clymer manual, but it only has so much info in it. also, the transmission was apart when i got to it, i was just putting it back together
    by crfsonly » Wed Nov 16, 2011 2:40 pm
    are you confident you put it back together correctly? all of the washers need to be in the correct order and orientation. if you are confident you may have damaged parts.
  • culprit1384
    by culprit1384 » Thu Nov 17, 2011 2:54 pm
    app1 wrote:i do have a manual for it. im using a Clymer manual, but it only has so much info in it. also, the transmission was apart when i got to it, i was just putting it back together
    MAKER SURE ALL WASHERS ARE IN THE RIGHT PLACES!!! Even though the seem small one misplaced washer will bind up everything. Also
    the Clymer should get you through it pretty well as i have used it before.. Send us some pictures of it together from different angles..
