any fixes for tweaked handlebars on 50s
  • curryd
    by curryd » Fri Nov 11, 2011 5:50 pm
    Been looking at used crf 50 for my daughter. Alot are scratched up. Plastic is cheap enough to replace so I am not really worried about that, but almost everyone has tweaked handlebars. Is there a fix for this?
    Daughter is 3 and will be 4 next summer so taller bars won't work. Just want to give her a "new" bike feeling for Christmas.
    2014 CRF 450r
    2000 CR 250R
    1986 TRX 250R
  • staffy24
    by staffy24 » Fri Nov 11, 2011 6:53 pm
    if you have a solid bench you can bolt them 2 it and then straiten with a steal pipe. you will need a bench with holes drilled, bar mounts, hollow pipe,you can use heat if you are carful
    over 40 still ridin hard
    still learning
