Fuel/Air Mix Adjustment
  • studawg66
    by studawg66 » Mon Sep 26, 2011 9:07 am
    Does anyone have a good procedure for adjusting the fuel/air mix on a 2004 CRF50? If not, what position should I start in now that I have completely cleaned the thing out? It was about 3/4 turn out before I disassembled and seemed to run okay (had to take it apart for another reason...bad float needle caused flooding), but I would really like to "tune it in" as best I can to prolong spark plug life and that sort of thing.
    Any tips are appreciated!
    Stuart
    by Back2-2 » Mon Sep 26, 2011 11:24 am
    Short and simple is in until a little stumble. Out until a little stumble then between the two settings should be just about right.
    Some people just go in until in stumbles a little then back out until it is smooth.
    Hope that helps a little.
  • studawg66
    by studawg66 » Mon Sep 26, 2011 11:33 am
    Thanks, Neil, that helps a great deal. I'll keep that in mind when I get it put back together.
    I guess I should also do this when the engine is warm, correct?
