Front wheel assembly 03 crf 150f
  • J Cady
    by J Cady » Sat Sep 24, 2011 4:11 pm
    Is there a difference in the front wheel assembly from 03-08? I noticed today when I stared to tear down my front end that not only did I blow the seals in the forks, I also bent the hell out of my rim! I found a couple on ebay for a 07 and 08 19x1.4 inch rim. want to know if they will work before I order a replacement.
    Aspired
    by Aspired » Sat Sep 24, 2011 5:14 pm
    The best way to figure that out is to check if the part number is the same if you check www.yeltrik.com and look up the part on each year bike. If the part numbers are the same the part is the same and the ebay item will fit.
    You can do the leg work yourself!
    I can't imagine the hub or anything change but check it out to be sure.
    The best suggestion - Make sure you have a manual!
Users browsing this forum: No registered users and 12 guests
