center bolt, at rebound adjuster
  • charvo
    by charvo » Sun Jul 24, 2011 2:33 pm
    center bolt is stripped badly, any ideas on how i can remove it?
    DON'T HESITATE ACCELERATE.
  • staffy24
    by staffy24 » Sat Aug 20, 2011 6:55 am
    more info needed but it is cheep to have your unit rebuilt
    over 40 still ridin hard
    still learning
  • VetJunior
    by VetJunior » Wed Aug 24, 2011 8:12 am
    I came across this same issue on a pair of SHOWA forks I rebuilt. Apparently the debris from the bushings has a tendency to collect at the base of the fork tube right by the center bolt threads. What I did to remove the badly stripped center bolt was tig an aluminum rod to the center bolt so I could pull and rotate at the same time. Worked great. Ultimately I had to replace the entire lug.
