2012 Honda CRF150RB/CRF150R Announced
    by crfsonly » Mon May 02, 2011 7:36 pm
    Look at the 2012 CRF150R/RB and you can tell by its new styling treatment it's an integral part of the CRF MX racing family. And as good-looking as it might be, the CRF150R's racing credentials run even stronger. Thanks to a new cylinder head, piston, camshaft and carburetor, this 2012 model boasts improved power, torque and driveability throughout the powerband. Updated suspension settings front and rear produce improved action through even the toughest of track conditions. All of which reinforce the CRF150R's premier position in racing circles.
    New for 2012
    New cylinder head, piston, camshaft and carburetor improve power, torque and driveability throughout the powerband.
    Revised suspension settings front and rear produce improved action through even the toughest of track conditions
    2012 CRF150RB-Expert/CRF150R Specifications
    Model: CRF150RB-Expert / CRF150R
    Engine Type: 149cc liquid-cooled single-cylinder four-stroke
    Bore and Stroke: 66mm x 43.7mm
    Compression ratio: 11.7:1
    Valve Train: Unicam, four-valve; 26mm intake, steel; 22.5mm exhaust, steel
    Induction: Keihin 32mm flat slide with throttle position sensor (TPS)
    Ignition: Solid-state CD with electronic advance
    Transmission: Close-ratio five-speed
    Final Drive: #420 chain; 15T/56T (CRF150RB-Expert) / #420 chain; 15T/50T (CRF150R)
    Suspension Front: 37mm fully adjustable leading-axle inverted Showa cartridge fork; 10.8 inches travel
    Rear: Pro-Link fully adjustable Showa single shock; 11.5 inches travel / 10.8 inches travel
    Brakes Front: Single 220mm disc
    Rear: Single 190mm disc
    Tires Front: 70/100-19 (CRF150RB-Expert) / 70/100-17 (CRF150R)
    Rear: 90/100-16 (CRF150RB-Expert) / 90/100-14 (CRF150R)
    Wheelbase: 50.6 inches (CRF150RB-Expert) / 49.6 inches (CRF150R)
    Rake (Caster angle): 27°48' (CRF150RB-Expert) / 27°02' (CRF150R)
    Trail: 96mm (3.85 inches) (CRF150RB-Expert) / 78mm (3.07 inches) (CRF150R)
    Seat Height: 34.1 inches (CRF150RB-Expert) / 32.8 inches (CRF150R)
    Ground Clearance: 13.2 inches (CRF150RB-Expert) / 11.9 inches (CRF150R)
    Fuel Capacity: 1.14 gallons
    Color: Red
    Curb Weight*: 187 pounds (CRF150RB-Expert) / 183 pounds (CRF150R)
    by crfsonly » Wed Nov 02, 2011 10:19 am
    What's new for the 2012:
    * New 32mm Keihin FCR style flat-slide carburetor and an improved “direct push” accelerator pump. Produces better jetting results and acceleration off-idle.
    * New cylinder head, piston, and cam for more power and torque while maintaining the useability of that power.
    * Suspension enhancements.
    If you look at the pure specs the 2012 Honda CRF150R looks just like the 2009. However, the new carb, head, piston and cam profile provide much needed carb and power refinements.
    redrider250r
    by redrider250r » Wed Nov 02, 2011 5:29 pm
    Man I was really hoping for a fuel injected model...
    "If you don't crash, you ain't goin fast enough"
    "The faster you go, the smoother it gets. (Unless saying #1 comes into play)
    2009 CRF250R (mine)
    09 CRF250R (brothers)
    08 CRF250X (dad)
  • PTUK
    Re: 2012 Honda CRF150RB/CRF150R Announced
    by PTUK » Thu Jul 02, 2020 1:17 pm
    Hi guys new here looking for latest model changes on CRF150R is the 2012 the latest update on the model?
