Rider Weight
  • jmccool
    Rider Weight
    by jmccool » Mon Nov 21, 2005 7:55 pm
    Does anyone know the rider weight that Honda designed the CRF150F for? This will help in my decisions as to how far to go with suspension mods on mine.
    Thanks,
    John
    PGer555
    by PGer555 » Tue Nov 22, 2005 3:44 pm
    In the manual fir the 230/150 the max weight is like 220 or something... I dont remeber the exact # but thats close
  • Stevie305
    by Stevie305 » Tue Nov 22, 2005 4:07 pm
    PGer555 wrote:In the manual fir the 230/150 the max weight is like 220 or something... I dont remeber the exact # but thats close
    Correct. Manual says 220#.
  • jmccool
    rider weight
    by jmccool » Fri Nov 25, 2005 7:02 pm
    thanks for the replies....I'm just trying to figure out if adjusting the preload with the washers and thicker oil in the front fork combined with cranking the preload on the rear shock will be enough suspension work for my little 150 to handle a rider weight of 175 lbs.....seems if the bike can handle 220 I should be OK, any thoughts?
  • SoCalChilio
    Re: rider weight
    by SoCalChilio » Sat Mar 04, 2006 11:34 am
    jmccool wrote:thanks for the replies....I'm just trying to figure out if adjusting the preload with the washers and thicker oil in the front fork combined with cranking the preload on the rear shock will be enough suspension work for my little 150 to handle a rider weight of 175 lbs.....seems if the bike can handle 220 I should be OK, any thoughts?
    The CRF250R and CRF450R are sprung for 175lbs. riders, considering the CRF150 is a playbike the weight is considerbly lower.
    You need to respring it!
Users browsing this forum: No registered users and 16 guests
