what is up with my slow jet (pilot jet)
    motonutty
    by motonutty » Thu Mar 31, 2011 11:01 pm
    I've just opened up the intake and drilled out the exhaust on my 05 crf250x. I got the JD kit. All runs just OK. Some issues at idle to 1/8 throttle. Stock was a 40 slow jet, JD kit had a 42 with 160 main, Bike ran hotter then stock(lean). I put in a 45, the fuel screw made no difference. also still hotter than stock. So I went to a 48 with a 165 main. Runs very good with 1/2 turn on the fuel screw. Soooo... While putting in the latest 48 slow jet I noticed that it screwed in very nice and easy for perhaps 4 turns, then it gets harder to turn, it doesn't seem like its seating but i don't want to "force" it. Oh yeah, I took out the jet to check. threads look perfect. I'm using a tiny screw driver so cant put too much torque, i think....I don't know what to make of it. Is the slow jet top out up against something spring loaded? The choke maybe? Is there a pressfit threaded sleeve that i have broken loose and now that is turning together with the jet? Any answers or ideas?
    Thanks.
    2005 CRF 250x CA
    49state x-cam, drilled exhaust, opened airbox,
    no screen
    JD red-165main-42slow 1-1/2turn fuel screw,
    pinkwire mod,
    1994 Ducati 916
    1974 BMW R75/6
    1955 BMW R50
  • staffy24
    by staffy24 » Fri Apr 01, 2011 2:56 am
    go with the 42 as recommended and also compare with other jet for thread length make sure your boot between air box and carb is sealed and look for any place air mite bypass the filter. the jet should screw in till it stops with out any force at about 0.3 N.m or 1.5lbf-ft
    over 40 still ridin hard
    still learning
    motonutty
    by motonutty » Sat Apr 23, 2011 7:47 pm
    Your right, so was James Dean(JD jetting). My eyes not what they used to be. I meant to start with a 42 but installed a 45 by mistake. Finally got back to jetting my bike and... 42SJ with a 160MJ 1.75 turns out on the fuel screw. I've got a 250cc rocket.
    no backfires
    no bog at all.
    Also the slow jet threads fine I just wasn't used to the feel. Does seem to snug up at the last 1.25 turn before it seats.
    Thank You
    2005 CRF 250x CA
    no screen
    pinkwire mod,
    1994 Ducati 916
    1974 BMW R75/6
    1955 BMW R50
