Headcount: No. of HotCams riders
  • How many HotCams owners up to this point?
    Poll ended at Tue Jan 17, 2006 1:44 pm
    Reply here if you're switched over to the hotcam
    5
    50%
    Reply here if you're seriosly considering the switch
    5
    50%
    Total votes: 10
    Monkeywrench
    by Monkeywrench » Fri Nov 18, 2005 1:44 pm
    Seems like there is a little buzz going around about the Hotcam and how busy Santa's elves might have to be this Christmas -- was just curious how many current HotCams riders we have at this point. :-k
    2006 450R
    Ravage
    by Ravage » Fri Nov 18, 2005 1:46 pm
    Im getting a hotcan this christmas from santa! lol
    I can't wait! :D
    -Aaron
    06 RM250
    04 CRF250X #724- SOLD
    03 XR250
    74 CB350
  • Ray
    by Ray » Fri Nov 18, 2005 7:26 pm
    Santa is coming to my house too with a Hotcam and an FMF Q Ti package.
    Ho Ho Ho
    05 CRF250X
    03 CRF230
    03 XR80
  • 40oz
    by 40oz » Fri Nov 18, 2005 7:33 pm
    have not switched from stock as yet but will next month.
  • ev
    by ev » Sat Nov 19, 2005 4:50 am
    Crower 320
    am happy with it
  • gmoyer
    by gmoyer » Sat Nov 19, 2005 3:39 pm
    Hello all,
    I have purchased the Hotcams Stage 1 based on the
    positive opinions here but have yet to install it, hope to soon. Has anyone who has installed one actually degreed it in or has installing it based on the timing marks on the sprocket been acceptable?
    Thanks,
    Galen
    Templeton, Ca
    '06 250X
    Monkeywrench
    by Monkeywrench » Sat Nov 19, 2005 5:01 pm
    I used the timing marks on the cam gear. Worked just fine. Hope you enjoy it, braaap!
    -matt
    2006 450R
    levy1
    by levy1 » Sat Nov 19, 2005 7:48 pm
    Love it! Best mod yet, especially for a CA model which has a 10 degree retarded cam from the factory. Probably will go for a Hi Comp piston and a new head next instead of the 270 kit.
    04 250X
    Stage 1 Hot Cam
    Big Gun Race Pipe
    All CCC mods
    Main 155
    Pilot 42
    Leak 70
    Needle Ctr Position
    Air Screw 2.0 turns out
  • fivefour
    by fivefour » Mon Nov 21, 2005 9:37 am
    Best bang for your buck!!!
  • SRKXRIDER
    by SRKXRIDER » Mon Nov 21, 2005 3:49 pm
    I have one of their cams on the bench along with ahigh compression piston that will go in this winter. I can hardly wait
    Monkeywrench
    by Monkeywrench » Mon Nov 21, 2005 4:37 pm
    Ok now I really curious...
    what does the high-compression pistion do? (I mean besides generate more psi I would guess)...
    Does it somehow allow more fuel/air mixture into the cylinder, and is there any risk in blowing a gasket someplace with a high-comp. piston?
    Any ideas on how much higher the ratio is over the stock piston?
    Very curious,
    :-k -matt
    2006 450R
    levy1
    by levy1 » Mon Nov 21, 2005 8:46 pm
    More HP but you might have to run race gas. Thats OK because the stuff smells great.
    04 250X
    Stage 1 Hot Cam
    Big Gun Race Pipe
    All CCC mods
    Main 155
    Pilot 42
    Leak 70
    Needle Ctr Position
  • cammed250
    by cammed250 » Mon Nov 21, 2005 8:50 pm
    Cam works great! Absolutely the best bang for your buck...as for race gas, that's all mine's ever had in it...I can't imagine running a 12.5:1 compression engine on anything less, no matter what the factory says!
