crfsonly wrote:i haven't done this personally. i know honda updated decomp assembly '07 450R. as a result your '06 X decomp assembly won't work with the '07 cam. it may be possible to get the '07 450R decomp assemply to use it with your '06 450X. however, there could be other issues like the cam gear. i have read others saying it won't work. it may be that they were saying this in terms of a direct drop in. i wonder if they tried the updated decomp assembly and a new cam gear. i'll be interested in what you find when you get yours.
i do know the '02-06 R cams will drop right in and use the same decomp assembly. i have a '05 R cam in my '05 X and love it.
crfsonly wrote:if you have everything then there's a good chance it will work. report back once you know for sure. on the performance, no it won't be just like an '03-06 450R. the heads are different as well as the ignition timing not to mention the wide-ratio trans. with this cam you could do the pink-wire mod to get the R timing and that will get you closer.
curryd wrote:Why a 07R cam? Something wrong with the 05?
crfsonly wrote:definitely interested in the results. i currently have an '05 R cam in my 450X so i'm personally interested in the difference between these two.
crfsonly wrote:excellent follow up. so as long as you have the entire carrier with the cam with the decomp it slides in no problem.
