CRF230F Rear Shock Replacement
  • silstarnz
    by silstarnz » Sun Feb 06, 2011 12:21 pm
    Hi Everyone
    I am looking to replace my CRF230F rear shock I am looking at puchasing a Works performance shock although I was wondering if anyone can advise me if they have replaced there shock and it they found it was worth while.
    also to note I have found that I can order a replacement shock in NZ through.
    http://www.bits4bikes.co.nz/parts/honda/1087.aspx
    YSSMZ366380TRL08 YSS SHOCK ABSORBER MZ366-380TRL-08 (MONO SHOCK) CRF230F $549.00 (NZ$)
    SPEC:
    ~ M = Rear Mono Shock Z = Emulsion Gas Shock 366 = Piston 36mm + Shaft 16mm 380 = Length 380mm T = Thread Spring Preload R = Rebound Adjustable L = Length Adjustable
    $549.00
    although am I better to get a works shock or this YSS shock
    my main concern is when I ride its normally 45min circuit trail rides. and I was not sure if the main reason that my shock has failed was due to over heating. also I find when I ride I get a sore rear and I only reasontly found out that my shock was stuffed and that was prob the cause but is it worth replaceing the seat I weight about 190LB with gear
    Any suggestion would be really helpful
    Oh and if I get the pro shock should I get an adustable compression unit?
  • scotsy
    by scotsy » Sun Feb 06, 2011 2:38 pm
    I'm in the UK and we use an aftermarket 'Hagon' rear shock which is nearly £300 and doesn't sound as good as the 2 you have mentioned. Many good reports of the WORKS shock, no idea about the YSS one but the length adjustability is a bonus :D
    You asked for tips?
    STAND UP let your legs absorb some of the movement instead of your ARSE :lol:
  • silstarnz
    by silstarnz » Sun Feb 06, 2011 2:42 pm
    scotsy wrote:I'm in the UK and we use an aftermarket 'Hagon' rear shock which is nearly £300 and doesn't sound as good as the 2 you have mentioned. Many good reports of the WORKS shock, no idea about the YSS one but the length adjustability is a bonus :D
    You asked for tips?
    Haha thanks for that I have sceen that there are seat replacement that I was thinking about but didnt know if its worth it :)
    does anyone else care to comment
    by crfsonly » Sun Feb 06, 2011 3:24 pm
    the works performance pro shock we offer is built to suit your weight and riding type and ability. yes get the fully adjustable pro shock. you will not be disappointed. here's a link:
    http://www.crfsonly.com/catalog/product ... ts_id/4019
    also, you can select a black spring if you prefer.
  • silstarnz
    by silstarnz » Sun Feb 06, 2011 8:31 pm
    crfsonly wrote:the works performance pro shock we offer is built to suit your weight and riding type and ability. yes get the fully adjustable pro shock. you will not be disappointed. here's a link:
    So excited :)
    my Order :)
    1 x CRF230F-Works Performance Pro Series Shock
    1 x CRF230F'03-10 - Guts Racing SOFT Seat Foam
    1 x Pro Taper Universal 1 1/8
  • bwedmore
    shock
    by bwedmore » Wed Apr 27, 2011 6:28 pm
    Bar none the best money i have ever spent on a bike, you will love it hands down.
  • silstarnz
    Re: shock
    by silstarnz » Wed Sep 14, 2011 2:24 am
    bwedmore wrote:Bar none the best money i have ever spent on a bike, you will love it hands down.
    I do love it thanks I have had it in a couple of months and doing down hills its amazing how quick it responds i also am able to drop the bike down a 5ft retainer wall and the back doesn bottom out it just does what it meant to
  • Eoth
    by Eoth » Tue Nov 06, 2012 7:17 am
    No arguments with what was previously said.. I went a cheaper route (but more time consuming) and installed a late 80's xr 600 shock. Really pleased with the result.
    by Old Dude » Tue Nov 06, 2012 1:07 pm
    eoth,
    I am doing the same with my 230 Dual Sport project. Did you have a new hose made for the remote reservoir or what? Pix?
  • Eoth
    by Eoth » Tue Nov 06, 2012 1:18 pm
    I'll have to take a pic later. Yes I had a new longer hose made up at the local hydraulic supply store (30 bucks). The only change I made other than that was to add a 90 degree elbow on the resivoir so that the hose routed along the side rather than sticking straight out...
    by Old Dude » Tue Nov 06, 2012 7:59 pm
    sweet! thanks
  • Eoth
    by Eoth » Wed Nov 07, 2012 8:12 am
    cant post pics... PM me your e-mail address and I will send.
