taco157 wrote:I have a 2006 450x with an annoying hesitation/bog.... This hesitation occurs on the stand and while riding. I happened when you wack the throttle quickly, ie: wheeling. works great if you roll the throttle slower, but i want it to be snappy.
Last year i cut the sides and top out of the airbox and removed the backfire screen.
Also installed the JD Jetting kit.... (which i praise big time)
Red Needle- 4th clip from top
165 main jet
0-800ft elevation
I want the bog gone this year... I just ordered the JD Leak Jet kit and the Boyesen Quick Shot 3.
Am i going in the right direction????
crazybrother wrote:order this from a Honda Dealer...
DIAPHRAGM SET, PUMP OEM part # 16021-MEN-A01
Then put in a 50 Leak jet...
You won't be disapointed
taco157 wrote:Ok, i did purchase the Diaphragm Set, and the JD Leak jet kit from this site... i assume the JD kit includes a 50 leak jet?
I ordered the Boyesen Quickshot through my work... is there any gains to using this at all? or should i just return it?
crazybrother wrote:Hey Ken, this would be good to pass on to the Folks on this site. As I tried to search for the part # on the Yeltrik site, but there is no way to cross reference the part #'s. It would be a good idea to include a search function that would work on OEM part #'s.
Thanks.
