Just a little FYI on mid and top end popping issue
  • ocechap
    by ocechap » Sun Jan 16, 2011 6:26 pm
    Just thought I'd write up the issue I was having and what the problem was. The bike was popping mid ish throttle when you whacked it open and then on top end. Thought it was jetting, cleaned everything, but still same issue. New spark plug changed. Still the same issue. Put my buddies carb on, and same deal.
    Well, it was the spark plug wire coming out of the coil. I put my buddies coil on and it ran like a top. Noticed my spark plug wire was loose, didn't realize the wire can screw off, but tightened it and put all back together.
    Runs AWESOME! So happy to fix and not spend a buck!!Thank goodness for friends with the same bike, LOL.
    Just thought I'd share! If your bike is popping and cutting out when you whack it or on top end, could be your plug wire.
Users browsing this forum: Google [Bot] and 21 guests
