crfsonly wrote:what you are probably hearing is slipping of the clutch and then dumping once theres enough traction to power out of the corner. ken
nedirtbikr wrote:crfsonly wrote:what you are probably hearing is slipping of the clutch and then dumping once theres enough traction to power out of the corner. ken
English please?![]()
By "slipping" the clutch, does that mean that you have approached the corner with appropriate speed and as you are going through the corner, you pull in the clutch and keep the throttle revved as your are going through the corner? Then as you are coming out of the corner, release the clutch (dump the clutch) and shoot out of the corner?
Don't mean to sound stupid, just trying to pick up on some of the lingo.
Thanks.
toyman2 wrote:why do guys rev and dump clutch in the corners
also nail it when they land
