PC Racing oil filter
  • mappsterr
    by mappsterr » Wed Nov 10, 2010 2:05 pm
    I have installed a PC Racing stainless steel, reusable oil filter in my 250x. When changing my oil, I clean it with contact cleaner (as prescribed by manf). Does anyone know how long I should let it air dry before re-installing and adding oil? I do not have an air hose to blow it out. If I re-install before allowing it to completely dry ( I let it dry for 2 hours), is my motor in any "real" danger?
  • mappsterr
    by mappsterr » Wed Nov 10, 2010 3:38 pm
    Thanks ~. I get the sense you do not believe in the performance of these filters? Do you think the engine is better protected using the disposable, paper filters each time?
  • mappsterr
    by mappsterr » Wed Nov 10, 2010 5:08 pm
    [quote="The danger is in the size of the particle that those stainless steel mesh screens allow through.
    No faith in these? Do you recommend the disposable filters instead?
  • bamm
    yup
    by bamm » Thu Nov 11, 2010 8:57 pm
    i asked the same question a few weeks back. All who replied said to stick with the disposable filters as they filter smaller particles.
  • mappsterr
    by mappsterr » Fri Nov 12, 2010 6:56 am
    Thanks for the response. I'll have to reconsider.
  • mappsterr
    by mappsterr » Wed Nov 17, 2010 1:18 pm
    Scotts Performance Reusable Stainless Steel Oil Filter
    DR Tested
    From the September, 2010 issue of Dirt Rider
    If you ride a lot, are good about maintenance and plan on keeping your bike for a while, the costs of oil filters can add up. There are plenty of reusable stainless steel filters on the market, but since I personally know what a meticulous and frugal person Scott Forward (the Scott of Scotts) is in regard to parts and performance, I'm confident he'd know a thing or two about reusing a filter on something as expensive to fix as a four-stroke engine.
    To put the filter to the test, I threw it on my egg-cooker Honda XR400 because I know that thing runs as hot as any four-stroke and would show a weakness in the bonding of the filter if there was any. Plus, the fact that I really work the clutch in that bike makes a real need for filtering of the plate material out of the oil.
    I change the oil filters regularly, every two oil changes, on my XRs. At $69.95 the Scotts filter took roughly 12 changes to pay for itself compared to the stock Honda disposable paper filters at a cost of $5 to $8, depending on the dealer. Some standard filters are a bit pricier (like KTM's, and there are two of them on some bikes!) so the Scotts may pay off quicker.
    The filter just works. It installs just as stock with no issues. I've cleaned mine four times now, back-spraying it with cleaner and seeing the results (small bits of debris) in a clean white rag. It filters particles to the size of 35 microns, passing certification in laboratory testing. For comparison, paper filters typically claim 50-65 microns. Also, the stainless steel mesh is impervious to water and flows cold oil better at startup. The filter still looks as good as new, and I suspect it will last the life of the bike. I'm also being semi-green throwing less stuff into the trash!
    So if you want to start saving a few bucks with every oil change, plus not worry about having the extra filter laying around (the better part of the deal), then I recommend the Scotts Stainless Steel Oil Filter. -Jimmy Lewis
    by JAWS » Wed Nov 17, 2010 7:33 pm
  • mappsterr
    by mappsterr » Thu Nov 18, 2010 5:55 am
    This certainly gives me a better understanding. Since this info is more than 3 years old, I am wondering if the stainless filters work better today? That being said, I am betting on the paper filters.
    Great info Joe -- thanks for digging this out.
    by JAWS » Thu Nov 18, 2010 7:19 pm
    You are welcome. I personally don't believe that much has changed in the interim for either filter type.
  • mappsterr
    by mappsterr » Wed Nov 24, 2010 12:13 pm
    First of all, CRF's Only forums are great. Second, I have found that if a little research is done before I post a question, usually the question has already been asked and answered . . .now I know.
    Here is another useful discussion you guys had 3 1/2 years ago on this topic - -
    http://www.crfsonly.com/forum/viewtopic ... sc&start=0
