too wide for my screen
  • ev
    by ev » Sun Sep 19, 2004 7:02 am
    Ken, your latest changes made your page too wide to fit my screen, I have to scroll sideways to read the full width :?
    was that supposed to be that way :?
    by crfsonly » Sun Sep 19, 2004 3:39 pm
    so, you've noticed some changes..great. i've set the width to 1000 pixels...and centered the view. are you able to grow the window and see everything so you don't have to go side to sidw the scrollers?
    let me know...i've tested it in both firefox and internet explorer and it works fine in both of these. anyone else having problems?
  • ev
    by ev » Sun Sep 19, 2004 5:11 pm
    crfsonly wrote:are you able to grow the window and see everything so you don't have to go side to sidw the scrollers?
    almost, only miss 1/2 an inch today
    and can read all
    thank you
    by crfsonly » Sun Sep 19, 2004 5:13 pm
    ev...if you open your browser to the full size of your screen are you still missing that 1/2 inch? what browswer are you using?
    thanks this information helps me.
  • ev
    by ev » Sun Sep 19, 2004 5:23 pm
    internet explorer 6.0.do-not-ask-me-what wide open
    max window
    1/3-1/2 inch
    by crfsonly » Sun Sep 19, 2004 5:31 pm
    ok..thanks. the square button in the upper right corner of the browser window (next to the button with an X in it - close window button) will grow the window to the screen size. you should be able to see everthing then.
  • dnold
    by dnold » Mon Sep 20, 2004 5:58 pm
    Im missing about 2 inches on my right side. I can see it if I scroll to the right. Its ok just a little anoying.
    by crfsonly » Mon Sep 20, 2004 6:22 pm
    check your display resolution and make sure it's set at 1024x768 and then when you expand the window to fit the display you'll be able to see everything. let me know if that works for you.
  • mikesx
    by mikesx » Wed Nov 16, 2005 12:07 am
    I reset my screen to view your pages and the type is just to small to read. Feels like im sitting ten feet from the screen. I use ie6 and this is one of just a few sites I have run into this problem.
    :!: Make the type bigger :!:
