Plated 450R Surging and popping / no idle / grayish plug
  • mpdddiesel
    by mpdddiesel » Sat Jul 24, 2010 9:41 am
    New to forum, need some advice, no good with carbs, so I've done some reading and still can't get this thing lined out...
    I am at sea level and riding a "plated" '04 CRF450R around town and to work. It sees 5th gear for about 3miles on the way to work and RPM ranges from 4800-5400...(45-50mph). The rest of the route is in town...stop and go traffic. I have one "fire road" excursion to finish my trip to work.
    Problem..Seems to be leaned out..plug is more gray than tan...
    Surging when throttle is held at 1/4 throttle (mostly during highway trip...4800-5400RPM range in any gear)
    Deacceleration Pop...
    Surge goes away when choke is pulled, or if throttle is whacked open...instant wheelie.
    Bike will not Idle when choke is off
    Haven't found any air leaks
    Hot Start is seating closed with a snap
    Throttle Stop screw turns, but hose is slipping. Is there an aftermarket solution to this design.
    Modifications and current settings....
    Uni Filter
    Yoshimura slip on
    5oz. over stock flywheel
    Trail tech lighting stator
    NGK IFR9H11 plug
    Pilot screw....1.5 turns out
    Slow jet...45
    Main...165
    Clip is in 4th position down from top/blunt end.
    I removed and cleaned slow jet, and put clip in 5th position from top on needle. Installed 175 main. Deacceleration pop is worse, hard to start and bike still will not idle. I'm going to put everything back to baseline and wait for some advice...
    Any help will be much appreciated...
    by Asmith » Sat Jul 24, 2010 10:09 am
    Has the carb been taken apart? Slide ever been removed?
  • mpdddiesel
    by mpdddiesel » Sat Jul 24, 2010 10:30 am
    [quote]Has the carb been taken apart? Slide ever been removed?
    *I don't think so.
    It idled fine when purchased, but has always surged a little as mentioned. It just started giving me trouble (deacceleration pop, no idle w/o choke) a few days ago and I decided it needed to be fattened up so I bought a step colder plug (was running an IFR8H11...went to a 9), and lowered clip to 5th position and installed 175 main.
  • mpdddiesel
    by mpdddiesel » Sat Jul 24, 2010 1:15 pm
    While setting main and air back to baseline I discovered two things...
    Throttle stop screw has cable under it...works fine :oops:
    Bike will idle while carb is turned too access air screw. I can adjust air, set idle, and whack throttle...no pops and it settles right back down to an 1800 RPM idle.
    As soon as I turn the carb the way it is supposed to be it dies. I can keep it started by opening throttle, but the backfire/pop comes back and it will not idle without choke.
    What is this telling me???
    by Asmith » Sat Jul 24, 2010 2:47 pm
    Could be the rubber boot between the carb and head is messed up.
    Could be the float level is wrong...should be 8.0mm.
  • mpdddiesel
    by mpdddiesel » Sat Jul 24, 2010 2:57 pm
    I'll remove carb and check boot/float level. Haven't checked valves...Should I have went there first? This is my first CRF. Last bike was XR...two totally different animals.
    Any links for checking/adjusting float level on the FCR carb?
  • mpdddiesel
    by mpdddiesel » Sat Jul 24, 2010 10:07 pm
    I checked my valve clearance..
    R Intake is 0.20mm or 0.008in
    L Intake is 0.15mm or 0.006
    L& R Exhaust is 0.35mm or .014in
    Decomp is 0.30 or .012in...so when combined with R. exhaust is (0.65mm or 0.26in)
    I have no idea about current shim size as I haven't taken it down yet. Do these measurements suggest I go ahead and pull the camshaft assy to check shims? Don't know how to do that yet...
    Any suggestions for the new guy?
  • mpdddiesel
    by mpdddiesel » Thu Jul 29, 2010 7:35 pm
    Floating Valve - Hole was on top
    Bike started - No deaceleration pop
    I can adjust fuel screw and achieve 1800 RPM idle speed, but now the bike shoots to 4000+RPM when I straighten the carb up... It's got to be something simple, but I've not found it yet.
    Any input on those valves?
    bambamsc
    by bambamsc » Thu Jul 29, 2010 8:26 pm
    Check the freeplay on your throttle. It sounds like you rotate it and the throttle cables are free. Rotate it back and it stretches the cable and is holding the throttle open. Adjust the cables so there is some freeplay in the throttle tube.
    by Asmith » Thu Jul 29, 2010 10:19 pm
    mpdddiesel wrote:Floating Valve - Hole was on top
    That's your issue...hole goes to the bottom... :shock:
  • mpdddiesel
    by mpdddiesel » Fri Jul 30, 2010 9:32 am
    bambamsc wrote:Check the freeplay on your throttle. It sounds like you rotate it and the throttle cables are free. Rotate it back and it stretches the cable and is holding the throttle open. Adjust the cables so there is some freeplay in the throttle tube.
    Man what a learning experience this has been.
    The Throttle stop was completely bottomed out in the carb and stuck. I was told by previous owner that dealership had replaced everything from the crank up including a thorough cleaning of the carb. I'm guessing the cable is broke inside. I manually turned it back down and missed the mark so now its idled too low. I'm going back in...
    Can I get the following parts at CRF's only?
    *Throttle stop screw/cable assembly
    *Remotely adjustable Fuel screw
    *14mm cap that covers the ignition side timing marks. Yes I hamfisted it and broke the cap :oops:
  • mpdddiesel
    by mpdddiesel » Fri Jul 30, 2010 3:20 pm
    Used needle nose pliers to adjust the throttle-stop until bike idled...Took it out for a ride and seems to be running much better. Ordered replacement throttle stop and adj. fuel screw.
    Sea level
    Main is 175
    Fuel is 2.0 turns out
    Clip is in 5th position
    Pilot is 45
    Floating valve - Hole is on BOTTOM
    Thanks for all the input. Great forum.
    by crfsonly » Fri Jul 30, 2010 4:57 pm
    yes we can get you anything you need. for OEM parts go to our OEM parts website, www.yeltrik.com for aftermarket go to www.crfsonly.com. for anything you don't see on these two websites PM me.
    momuzik
    by momuzik » Thu Aug 18, 2016 11:32 am
    Im having the same issue with the engine not idling and is constantly at high idle and not returning to low proper idling speed, in your post you mention floating valve hole on bottom, can you let me know what that is as I am unsure or provide a foto.
    any enlightment on why my throttle is not returning to proper idle speed would be gravely appreciated
    Leak 70
    Main 152
    Pilot 42
    Leak 58
    Altitude 150 feet
  • mpdddiesel
    by mpdddiesel » Thu Aug 18, 2016 6:50 pm
