oil cooler-oil pump?
  • mxersraz
    by mxersraz » Wed Jun 09, 2010 5:39 am
    Hi fer's.
    I've purchased the jagg oil cooler kit for my 450x and i'm a bit worried about something...
    Does the oil pump have enough power to provide oil to the oil cooler; or i'll have to make any other changes besides just installing the kit?
    Thanks.
    Back to the nature!! 450x
  • mxersraz
    by mxersraz » Mon Jun 14, 2010 4:57 am
    No one?
    I'm about to mount it on tomorrow and i'm a bit worried about it..
  • mxersraz
    by mxersraz » Fri Jun 18, 2010 1:56 pm
    :shock:
    installed it today but still :?:
    Even the mechanic was anxious about the pump.
  • Triumph650bob
    Re: oil cooler-oil pump?
    by Triumph650bob » Tue May 11, 2021 8:42 am
    my gut feeling is run it and feel how hot it gets-- if it gets a hot input and a warm output then you know the oil is flowing in and out as it should. see if it warms up rather quickly after you start the engine that will tell you about the flow also. my xr 400 has nothing special about the oil pump and it pumps through a oil cooler as a stock setup.
