amaviper wrote:So was this your final set up?
48 pilot
120 main
power up needle in the 4th position from the top
etuke wrote:i have been running the 48p and 120m with the needle in the 4th pos.I found it fouled up the plug quickly,turning it black.It would hesitate at full throttle and had little acceleration high in the rpm.I have since put the needle at 3rd pos and the hisitation is gone but not a big puller in the high rpms,I haven't checked the plug to see if it was still black.I have a 45p ordered but I may keep the 48 if the plug looks ok now.
etuke wrote:I have an 07 and it came allready jetted,I just added the 120M,I know the needle has the 5 different positions but it may be the power up needle.The flatening you described is exactly what is going on with mine and it happens at 3/4 throttle,it just seems to run out of acceleration.Is there any markings on the needle to determine which 1 I have?
VortecCPI wrote:etuke wrote:I have an 07 and it came allready jetted,I just added the 120M,I know the needle has the 5 different positions but it may be the power up needle.The flatening you described is exactly what is going on with mine and it happens at 3/4 throttle,it just seems to run out of acceleration.Is there any markings on the needle to determine which 1 I have?
The 03-05 needle is p/n 16012-KPS-901 marked C39A
The 06-09 needle is p/n 16012-KPS-731 marked C83A
The Power-Up needle is p/n 16012-KPS-921 marked C30FF
The 03-05 and 06-09 needles look very much the same but the 07-09 has only two clip positions equal to #2 and #3 on the 03-05 needle.
You will not believe how well the 230 pulls on top after you get the 03-05 needle installed at #4. I always thought the top end was "dull" due to the two-valve head design - Boy, was I wrong!
etuke wrote:well mine has the proper needle from the 03-05,have to have it in the middle clip or top end is even worse.Temps may be affecting it some,its only been 3-6 degrees Celcius here.On a bright note the plug color has improved greatly,I'm running a dark tan color now instead of dark black.
VortecCPI wrote:I should have thrown that 921 needle in the garbage but I really wanted to find out for myself. I used to work in a speed shop and I rejetted MANY Holleys and Quadra-Jets for both the street and the strip. I have also done quite a few bikes along the way too. This was not my first rodeo so I figured why not REALLY see what's going on. The bottom line is that Mike Coe spent hours on a dyno and it is just foolish for us to question his work - PERIOD.
