2005 CRF150F soft clutch lever. Normal?
  • jhawk14200
    by jhawk14200 » Wed Mar 10, 2010 9:23 am
    I just recently picked up a pretty nice used 2005 crf150f. I replaced a couple of worn parts - grips, tires, replaced fork boots with seal savers because one was ripped. I also replaced the clutch lever because it was tweaked. It seems to work properly but it pulls back so easy a two year old could do it. Should I worry about it? Is it a sign of a worn clutch or clutch springs? I think I have it adjusted right, as it felt the same way before I swapped the lever out. And I took it for a spin and it seems to be working fine. Any insight would be appreciated.
    2005 CRF250X Jd kit, 160 Main, 42 Pilot, CRFSONLY fuel screw 1 1/2 turns out, exhaust drilled, airbox mod.
    2004 CRF70F
    2008 CRF80F
    2006 CRF100F
    2005 CRF150F
    mcdanic
    by mcdanic » Tue Mar 16, 2010 4:01 pm
    the clutch on mine pulls back fairly easy. it shouldn't just "fall" back though. but it doesn't pull back like a big motocross bike or anything.
  • jhawk14200
    by jhawk14200 » Wed Mar 17, 2010 9:14 am
    It doesnt just fall back, but is very soft even compared to our crf80f and crf100f. The wife kinda likes it like that but I just wondered if it were normal for the crf150's.
    2004 CRF70F
    2008 CRF80F
    2006 CRF100F
    2005 CRF150F
  • dsrpilot
    by dsrpilot » Wed Mar 17, 2010 10:42 am
    Just pulled on the clutch levers of our 80, 150 and 230. All of them felt about the same.
    '12 CRF450X - son
