04 CRF450 Problems Separating Inner and Outer Fork Tube
  • jeffal621
    by jeffal621 » Mon Mar 08, 2010 2:46 pm
    I am putting new fork seals on my 04 crf450. I already completed one fork, but on the second one I cant separate the inner and outer fork tube. I have tried everything. Anyone ever run into the same problem or have any tips/tricks to separating them? Please help. thanks
    crazybrother
    by crazybrother » Mon Mar 08, 2010 2:49 pm
    Check out this video, maybe it will help.
    http://www.pivotworks.com/index.cfm?fus ... &videoid=1
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
  • jeffal621
    by jeffal621 » Mon Mar 08, 2010 2:58 pm
    Thanks, I just checked it out. But the slide hammer technique isnt working. The fork gets stuck really easily when its pulled out and has to be forced back in to compress. Its feels like the bushing or washer may be catching on something. Im out of ideas.
    by Asmith » Mon Mar 08, 2010 3:11 pm
    Yup. The large bushing is getting hung up on the smaller one.
    2 Things.
    1) You WILL need to put new bushings in now. The teflon will be ruined when you finally get them apart.
    2) Use a propane torch to gently heat the area containing the seal/bushings from the outside of the tube. Be careful with fire. :shock: Once warmed up, they will separate.
  • jeffal621
    by jeffal621 » Tue Mar 09, 2010 10:53 am
    Cool, I will try it and let you know. Thanks alot!
  • jeffal621
    by jeffal621 » Fri Mar 12, 2010 1:10 pm
    The torch worked!! Fork seals, bushings, and o-rings are all new and done. And did it all without special tools. Thanks!
    motosicko
    by motosicko » Fri Mar 12, 2010 1:49 pm
    jeffal621 wrote:The torch worked!! And did it all without special tools. Thanks!
    What are you saying??? ~ isn't a "Special Tool"??? :lol:
    "There are old racers
    and there are bold racers,
    by Asmith » Fri Mar 12, 2010 2:36 pm
    I've been called worse... :shock: :lol: :lol:
