450X Jetting Questions
  • ST310
    by ST310 » Mon Nov 09, 2009 7:22 pm
    Can anyone offer some jetting advise?
    I have a 450X with stage 2 Hot Cam, oversized SS valvs, pro circuit exhaust, air box mods. The current jets are 170 main / 45 pilot. It was running rich, so I changed the needle from notch for from top to notch 3 (dropping it further into the jet, and I changed the fuel/air screw in from 2.25 turns out to 1.5 turns out. I'm hoping this will lean it out, but I am wondering if I should be changing the jetting while I'm at it.
    wmrice
    by wmrice » Tue Nov 10, 2009 5:39 pm
    What needle are you running? Also, where do you ride as far as temperature and elevation?
  • ST310
    by ST310 » Wed Nov 11, 2009 6:22 am
    JD Red 3rd position.
