jorem50 wrote:Thanks ~
Looks like I have everything I need. The only other question I have is the Hot Cams Shim kit comes in .05 increments and the Stock Honda shims come in .025 increments. Is it possible to run into an issue where I will need one of those in between sizes?
jorem50 wrote:~
It doesn't make sense to me why putting it in gear and stepping on the rear brake would work but since you are the resident expert on heads I decided I would take your word for it and try it. The cam still kept turning. Since it did not work would that indicate another problem?
I ended up getting the bolts out and finished my valve adjustment. Only took me two and a half days, next one should only take an hour or so.
Thanks for the Info
