CRF150R Problems (Rekluse) Kickstart Jamming etc
  • halgaruk
    by halgaruk » Tue Jun 02, 2009 3:36 pm
    Recently installed Z Start Pro from Rekluse, everything seemed to of went well... Kicked the bike off, and the clutch was doing its job.
    Today I took it for a test, and seemed fine at first. But not long after, I noticed that the Kickstart was jamming, which it has never done before. Also started hearing rattling (like balls knocking together), when at very low speed, but sounded fine when giving it throttle.
    Brought the bike back and had a look at the clutch and all ball bearings are still in place, and looks how I left it after install.
    Have I done something wrong during install thats causing this?
    What would cause the Kickstart to Jam up?
    Thanks in advance for your help....
    Gary
    2007 CRF150R
    by [email protected] » Wed Jun 03, 2009 4:18 am
    It's always a clue when something wasn't a problem before a procedure was performed that something was missed.
    Look at a picture of the kickstarter set-up, pull the cover,call Rekluse, etc. Doug
    motosicko
    by motosicko » Wed Jun 03, 2009 7:30 am
    Sounds like you didn't get the return spring for the kickstart gear positioned correctly.
    "There are old racers
    and there are bold racers,
  • halgaruk
    by halgaruk » Wed Jun 03, 2009 8:08 am
    Cheers Fellas,
    I rang Rekluse this afternoon, and Rob confirmed what you said... the Kickstart spring is not set in properly.
    Gary
    2007 CRF150R
