Need some CRF100 help, back fires and tires.
    Riley
    by Riley » Sat May 23, 2009 8:12 am
    Kinda rhymes huh?
    Any way, my wifes 100 was back firing a lot yesterday, generally after cresting a hill and starting back down. Not really sure as I wasn't riding it.
    Totally stock carb and engine.
    Also, any idea on tires and pressures? The stock Maxxis hard terrains aren't the best. She had a hard time in the rocks and such, lowered the pressure and it was better but I think the tires are lousy.
    Should I go with the same as what I'd put on my 250x? Dunlop 756/952 with heavy tubes?
  • fmhscracer
    by fmhscracer » Sun Feb 07, 2010 2:20 pm
    1] The popping is probably due to jetting, although there could be other minor things.2]I usually run 14 in the front and 16 in the back for harescrambles, but less should be used for tracks.
    FMHSC
    '09 #1150
    '10 #981
