OK will not start again no compression took off head and checked valves for leaks took off cylinder to check rings both seem to be in great shape.
Took down to the local rebuild shop had a vacuum test done on the valves no problem there.
The bike has been down for 16 days and I'm ready to put it out by the dumpster.
I put it back together and still no compression I was about to buy a leak down tester when a buddy said he had one maybe I 'll find out whats happening to it.
After this if I dond figure it out I,ll need a good shop to take it to.
I live in Cypress any suggestions.
And if I've fixed your bike no crap from you guys I just can't fix my own.
