Heres a little information about suspensions....
  • CRF916
    by CRF916 » Tue Apr 21, 2009 12:25 pm
    Heres a little information I found about suspensions. It might help to better understand what your bike is saying to you without saying it.
    Suspension Setup Tips
    TROUBLE SHOOTING
    Various tracks or trail systems may require slightly different settings. Changes made in settings
    should be done 1-2 clicks (LS Comp. / Rebound) or 1/4 - 1/2 turn at a time (HS Comp.).
    COMPRESSION:
    Compression damping controls how soft / hard the fork or shock is when compressed. Some
    machines have only a Low Speed Compression adjuster on the shock. The Low Speed
    Compression damping is adjusted by clicks. Other shocks today also have a High Speed
    Compression adjuster in which the damping is adjusted by turns. Low Speed&High Speed
    Compression are terms that relate to how fast the fork or shock is being compressed. High Shaft
    Speed creates more damping and is not necessarily relative to motorcycle speed. High Shaft
    Speeds can be created at low motorcycle speed. Examples of High Shaft Speed obstacles:
    square edged bumps, slap down landings, lipped out jump faces, logs. Examples of Low Shaft
    Speed obstacles: rolling bumps / whoops, steep jump faces.
    REBOUND
    Rebound damping controls how quickly the fork or shock comes back up after being compressed.
    The Rebound damping is usually adjusted by clicks.
    BOTTOMING:
    Is caused by lack of compression damping or too soft of a spring rate. Correct by adjusting the
    compression damping stiffer until bottoming is under control. If you run out of adjustment and
    bottoming still exists consistently, a stiffer spring rate may be necessary. If spring rate is correct,
    too much compression damping is added and harshness is felt in forks then oil level can be
    raised to increase bottoming resistance. (Generally 10cc / 10mm (consult your shop manual for
    oil level ranges).
    SHOCK - Is caused by lack of compression damping or too soft of a spring rate. Correct by
    adjusting the compression damping stiffer until bottoming is under control. Note: If the
    components have a lot of time on them, bottoming or a soft, springy feeling can be an indication
    that a service or rebuild is necessary.
    HEADSHAKE / HARSHNESS:
    FORK - Is generally caused by too much compression damping in the forks. Soften compression
    1-2 clicks. Lighter riders for the size bike you are riding may find it necessary to change to softer
    fork springs. Too much rebound damping can also cause a "packing" situation in which the
    damping holds the forks down in a stiffer area of the travel than is needed. Soften rebound
    damping 1-2 clicks. Other causes can be:
    a) Improper fork installation or binding of the fork.
    b) Improper shock set up which causes the fork to ride too far into the stroke.
    Too much air pressure in your front tire will cause some deflection and harshness feel to
    your forks. We recommend only 11-13 psi of pressure.
    BACK END KICKS SIDE TO SIDE:
    SHOCK - Generally caused by too much compression damping on most types of terrain. Too
    much compression damping on square edge terrain can cause the back end to kick side to side
    and/or lose traction. Also, too much rebound damping will cause this because the back end is
    held down in a stiffer area of the travel which in turn makes it too stiff for the bumps it's hitting
    (packing).
    BACK END KICKS STRAIGHT UP:
    SHOCK - Generally caused by too little or not enough rebound damping. Slow rebound damping
    1-2 clicks. Note: In some applications rebound affects compression damping. Adding too much
    rebound stiffens the shock damping, decreasing rebound too much softens the shock damping.
    VARIOUS TRACKS:
    HARD TERRAIN / BLUE GROOVE TERRAIN
    Generally adjust compression as soft as possible to handle square edges while still having some
    control with bottoming.
    INTERMEDIATE / LOAMY TERRAIN
    Generally adjust a little stiffer for the softer terrain, jump faces and bottoming. Optimum settings
    still should be on the softer side for square edges and rutted corners.
    SOFT / SANDY TERRAIN
    Generally, stiffen compression and rebound. You want the bike to ride on top of the terrain,
    allowing the forks to ride up a little higher.
    ROCKY / ROOTY TERRAIN
    Generally you need compression very soft to absorb the sharp hits. Rebound is generally
    softened to provide a very responsive feel and ride.
    0'6 CRF450XXX
    belltownjefe
    by belltownjefe » Tue Apr 21, 2009 3:07 pm
    Good stuff! :D :D :D
    MentalMike
    by MentalMike » Tue Apr 21, 2009 3:34 pm
    Great stuff for the newbies ;)
    Mike
    2005 CRF 250X (Plated)
    1982 Kawasaki KZ1000J ELR
    1984 Kawasaki ZX750A GPz
    1978 Kawasaki KZ650 Custom
  • shorty99
    by shorty99 » Wed Jun 10, 2009 3:53 pm
    Which way do you turn to soften rebound
    motosicko
    by motosicko » Wed Jun 10, 2009 5:17 pm
    Hard or slow is clockwise, Soft or fast is ccw.
    "There are old racers
    and there are bold racers,
  • shorty99
    by shorty99 » Thu Jun 11, 2009 6:55 pm
    Thanks, it feels like my front end never grips when corning always whats to jump out of the berm.
  • charvo
    by charvo » Sun Feb 14, 2010 8:48 am
    Good info. i've been looking for a decent guide like this.
    suspension can be a mystery. My question thou. Is the stock setting a good balance between the front and read suspension for an average weight person?
    the guide should be a sticky too.
    DON'T HESITATE ACCELERATE.
  • sirmish
    by sirmish » Tue Mar 09, 2010 3:15 pm
    my front end goes straight up when i jump with a paddle tire on. I'm wondering if I can compensate for that with the clickers or is it just a paddle tire thing.
    by Asmith » Tue Mar 09, 2010 3:21 pm
    sirmish wrote:my front end goes straight up when i jump with a paddle tire on. I'm wondering if I can compensate for that with the clickers or is it just a paddle tire thing.
    Rotating mass thingy...tap the rear brake slightly.
    by 124 » Wed Mar 10, 2010 5:26 am
    ~ wrote:...tap the rear brake slightly.
    Uggghhh...that is Sooooo late 90's!! :roll: :lol:
    by krisrtch » Wed Mar 10, 2010 6:00 am
    Could be body postioning as well when leaving jump face. aka seat bouncing
  • crf45
    by crf45 » Mon May 17, 2010 11:43 am
    Still a little confused with rebound. (Motosicko wrote "Hard or slow is clockwise, Soft or fast is ccw") lets say the front tire tends to wash out around turns especially if the dirt is a little pebbly and the front end rises too fast off jumps, could rebound settings affect this if so would I want to adjust it harder or softer?
    by Asmith » Mon May 17, 2010 1:32 pm
    crf45 wrote:Still a little confused with rebound. (Motosicko wrote "Hard or slow is clockwise, Soft or fast is ccw") lets say the front tire tends to wash out around turns especially if the dirt is a little pebbly and the front end rises too fast off jumps, could rebound settings affect this if so would I want to adjust it harder or softer?
    Clockwise on the rebound...Harder...Slowing the speed of the rebound.
  • crf45
    by crf45 » Tue May 18, 2010 10:42 am
    thanks, I'll give it a try next time out.
    Re: Heres a little information about suspensions....
    by [email protected] » Thu May 20, 2010 3:55 pm
    CRF916 wrote:Heres a little information I found about suspensions. It might help to better understand what your bike is saying to you without saying it.
    Whicked... Thx!
