08 CRF450X jetting?
  • jsnotech
    08 CRF450X jetting?
    by jsnotech » Mon Mar 16, 2009 1:12 pm
    Yep, just got off the CR500 and moving onto a 450X. I bought a new 08 and I've read about cutting the air box. I ride at 5000'-7500' elevation and from 40-95 degrees. Nevada is dry and open like SoCal.
    So how about the Carb? (stock is FCR13B)
    -Main jet size (stock is #145)
    -Needle size (stock is NNEU) does this Needle from a 04' CRF450R work here also?
    -Clip position (clip position fixed this year?)
    -Slow/pilot jet (stock is#45)
    Thanks for responding! I'll miss that oil burner :cry:
    by Skoot22 » Mon Mar 16, 2009 2:02 pm
    stock pilot is fine.
    165 main jet
    Yes the 04 450R needle will work great. For your elevation put in 3rd pos.
    Part # NCVS 16233-MEN-671
    I believe the 08 has a fixed Fuel Screw as well. So an aftermarket one will be needed. Look into the Crf's Only fuel screw. Its in the Catalog here online.
    Welcome to the site.
  • jsnotech
    by jsnotech » Wed Mar 18, 2009 10:21 pm
    thanks. what i have learned lately is...
    -stock, sea level is good with no intake or exhaust mods. Maybe for break in period.
    -Some think you can get away with the air box mod or removal of the exhaust baffle with the stock jetting, but not both.
    -block off the smog equipment.
    -a CRF450R cam.
    ?Do the JD kits come with smog equipment block off parts? I'm headed there (web site) next. How do you block off the smog equipment?
    Rode for 2 hrs. on monday for the first time. I like this bike so far.
    by Skoot22 » Thu Mar 19, 2009 5:06 pm
    Airbox and Jetting is a must and needs to be done at the same time.
    You have an 08, you baffle is not removeable like the 05-07's
    JD kits come with 2 needles, a few main jets, and an o-ring for the ap mod, no smog block off stuff. Applied Racing makes a kit sold here. Or look in the stickies for smog block off done with JB Weld.
    05 450R cam is a great mod. At that point Jetting will need Richened up a touch, and Pink Wire mod
  • jsnotech
    by jsnotech » Fri Mar 27, 2009 4:15 pm
    Thanks
    Kiwi
    by Kiwi » Fri Mar 27, 2009 5:18 pm
    Spanish Springs?! That's near my old stomping grounds (grew up in Carson City, went to college in Reno). I still ride with my buddies in Carson (we recently rode at Sand Mountain) and my 2007 450X has ... as runs great with:
    -Modified airbox including side slits cut out
    -Aftermarket air filter with factory backfire screen removed
    -stock idle/slow jet
    -172 main jet
    -NCYS needle on the fourth position (winter) and 3rd position (summer). Note: NCYS is a bit leaner than the NCVS. Done over I'd probably go for the NCVS.
    -CRFs Only idle screw
    -Pink wire mod
    -Factory exhaust header with Pro Circuit T-4 slip-on muffler
    -Aftermarket camshaft
    Thus, if your bike is all stock (factory exhaust, cam, etc) with the exception of the airbox mods and aftermarket air filter, I'd suggest:
    -165 or 167 main jet
    -CRFs Only idle screw (about 2 turns out)
    -NCVS needle on the third clip position
    If you later add aftermarket exhaust, up the main to a 170.
    2007 CRF450X with modified airbox, Uni filter w/no backfire screen, NCVS needle on 4th, 172 main, CRFs fuel screw at 2, Boyesen QS3, stock smog, 450R cam, FMF Megabomb header, Pro Circuit T-4 muffler, Pro Taper Evo bars, AS suspension
    belltownjefe
    by belltownjefe » Fri Mar 27, 2009 5:25 pm
    Scoot has pretty much nailed it with the exception of the fuel screw. It is adjustable but a pain in the a$$ to do it. There are a couple of different methods to make it easier. Some guys shove a wire butt connector over it to turn it. They also make a wrench which isn't worth the $40 they want for it. The other option is rotating the carb and removing the float bowl to adjust it. Here is what I have done so far and I have the same bike as you. I ride the same elevation and climate.
    Year: 2008
    Elevation: 4000+
    Temperature Range: 40* - 100*
    Smog (AIS): Applied Racing Block Off Kit
    Airbox Modified Top: Yes
    Airbox Modified Sides: No
    Backfire Screen: Removed
    Air Filter: Stock
    Pilot Jet: 45
    Main Jet: 170
    Needle: NGGQ
    Needle Clip Position: 4th
    Fuel Screw Type: Stock
    Fuel Screw Setting: 2 Turns Out
    AP Modified: No
    Leak Jet: 65
    AP Cover: Stock
    Exhaust Type: XR's Only Gen II Full System
    Exhaust Modified:
    Pink Wire Modified: Yes
    I just got and adjustable Zipty Fuel screw that I should be installing here in a week or two. I need to dial my pilot a little bit, but so far the power and response is great from mid to top which kicks a$$ for open desert. I hope this helps.
