Post Reply 92 posts
Jetting database for Honda CRF's
    speedilad
    by speedilad » Tue Sep 20, 2005 10:50 am
    Please post with:
    Model: 450X or 450R or 250X or 250R
    Settings for what altitude: nnnnn ft
    Main jet size:
    Needle used: Stock or otherwise
    clip location: 2nd, 3rd, etc.
    Airbox mods: cut open, stock, etc.
    Air Filter changes:
    Any other related changes:
    If you ride at different altitudes, make an entry for each...
    Thanks! Jim CRF450X 2005
    by crfsonly » Wed Sep 21, 2005 9:45 am
    speedilad...welcome to the group. so why the range of requests for jetting information? looks like you have a 450X?
    i think speedilad has a good point. it would be great if everyone would have in their signature their jetting and needle settings along with altitude and location. this would be a big help to others. me personally, i doubt i'll do anything other than have jd jetting kits installing in all of our crfs. they work that well and eliminate the day or so of jetting and testing.
    -r0b-
    Re: Jetting data base for crf's
    by -r0b- » Fri Sep 23, 2005 5:35 pm
    speedilad wrote:Jetting data base for crf's
    I'm in.
    Model: 05 450X
    Altitude: 450MSL
    Main jet size: 160
    Pilot Jet: 42
    Needle used: 16233-MEN671
    (I think the stock needle would work just fine but in 4th clip)
    Needle clip location: 3rd Clip
    Airscrew: 1 1/8 turn
    Airbox mods: Top of box cut away. No holes in outside
    Air Filter changes: Stock filter
    Other related changes:
    Headlight on/off switch
    Race Sag: 3.5 inches
    Forks: Raised 1.5cm
    Rekluse Z-Start Auto Clutch w/ Perch Adjuster
    Flatland SkidPlate
    Pro-Taper Fatbars
    Scott's Steering Damper
    BRP Bar mounts
    Acerbis Multiplo BarkBuster
    Fastway Case Saver
    Works Connection Shark Fin
    Works Connection Rear Master Cylinder Cover
    Unabiker Radiator Guards (www.unabiker.com)
    RBR Wheel Spacer/Seal Savers
    Progrips - Safety wired
    Custom License Plate bracket
    Dunlop 756s Front and Rear
    Pink Wire Mod
    Lynx Computer w/ Remote Switch
    Fastway Wheel Spacer
    Stock Exhaust w/Baffle removed
    Mobil V-Twin 20/50w Synthetic
    -r0b-
    Middle TN
    Lurker Extraordinaire
    speedilad
    by speedilad » Mon Sep 26, 2005 12:16 pm
    Yes I do have a 2005 CRF450X - first rides this week - awesome. Home ride is in Eastern Penna. Annual trips to Colorado and Utah. Looking to help others that are new to 450X and maybe save myself and others time. The XR400R riders had an excellant data base with about 25-30 entries from riders all over the map...
    I am planning on creating a pdf file report of the results and post it here when done.... Not many takers so far...
    -r0b-
    by -r0b- » Mon Sep 26, 2005 12:28 pm
    speedilad wrote:Yes I do have a 2005 CRF450X - first rides this week - awesome. Home ride is in Eastern Penna. Annual trips to Colorado and Utah. Looking to help others that are new to 450X and maybe save myself and others time. The XR400R riders had an excellant data base with about 25-30 entries from riders all over the map...
    speedilad,
    Might post a notice out in the general forum to let everyone know to come here and fill it out.
    -r0b-
    Middle TN
    speedilad
    by speedilad » Mon Sep 26, 2005 12:47 pm
    Rob,
    I looked. Where is the best place to post as you suggest? I don't see a general topic.. Thanks!
    Jim
    -r0b-
    by -r0b- » Mon Sep 26, 2005 3:08 pm
    I'd put a post in each of the targeted categories, ie., 450R, 450X forums.
    -r0b-
    Middle TN
    by [email protected] » Thu Sep 29, 2005 7:50 am
    05 CRF 450X 700 ft. ASL.
    JD kit per directions -Red needle in 4th clip, 45 pilot, 1 and 3/4 out on the fuel screw,162 main jet
    HotCams Stage 2 camshaft
    Crfsonly fuel screw
    Twin Air Powerflow
    Air Box sides/top open
    FMF PowerBomb header with Yoshimura slip-on.
    Pink Wire Mod.
    Applied Triple Clamps
    Rekluse with perch adjuster
    Scotts steering dampener
    AceWell 3700 speedo/computer
    Cycra ProBends hand guards
    Applied crankcase vent kit
    TyDavis axle blocks
    Hammerhead shift tip (For size 14's !)
    Pingel oil filler cap
    Bitchin' red valve stem covers
    Unabiker radiator guards
    Race Tech re-spring/re-valve front and rear
    TM DesignWorks buffer/guide/rollers
    Works Connection Elite clutch perch
    IMS footpegs
    IMS 3.2 fuel tank
    Project 321 gas cap
    Last edited by [email protected] on Fri Mar 09, 2007 5:53 am, edited 2 times in total.
    by paul turner » Sun Oct 02, 2005 11:43 pm
    crf450x 2500'-9500' tested
    '05 R Cam
    12.5:1 JE Piston
    36mm TRX Intake Valves
    JD Red Needle 4th pos.
    170 Main
    45 Pilot
    XR's ONLY Fuel Screw @2.25 avg.
    BOYESEN APC {a must}{no adjustments to linkage}
    O-Ring Mod to linkage
    PINK Wire Mod
    AIRBOX Mod per Honda Wrench {emulates R box}
    TWINAIR Air Filter {backfire screen removed}
    TWOBRO CAN
    paul #1
    by Ernie Pezz » Tue Oct 11, 2005 9:11 pm
    JD kit
    Red needle 4th clip position
    170 main
    45 pilot
    Twin Air Powerflow
    Opened airbox (Completely Hacked)
    Boyesen APC
    XR's Only Fuel Screw. 1-1/2 out TBD
    "R" Can with PMB end cap
  • barryh
    Jetting
    by barryh » Wed Oct 12, 2005 8:44 pm
    158 Main
    45 Pilot
    I live at 1180 ft above sea level. Really woke the bike up and stopped the pinging.
    Barry H
    BDude
    by BDude » Thu Oct 13, 2005 6:30 pm
    First off, JD gets it REALLY REALLY CLOSE! But, I spent DAYS perfecting this!
    Altitude: 300ft
    JD jet kit
    172 Main jet (not in kit, but needed)
    Red needle on 5th from top (tried 4th from top as recommended but just to lean mid throttle. between 4 and 5 would really be ideal!)
    Screw is 1.5 turns out (1.75 and the bike will stall with a quick tap of the throttle. same for 1.25)
    All mods are listed in below. Throttle is response better than many two strokes!!!
    '05 CRF450X, FMF full Ti Power Bomb exhaust, JD Jet kit (172 main), Pink mod., air box CUT, Boyesen QuickShot, IMS 3.2 tank, Twin Air filter kit, RK gold XW chain, Ironman 13/50 sprockets.
    BDude
    by BDude » Thu Oct 13, 2005 6:36 pm
    Oh yeah, It didnt have any change on jetting at all, but I changed to 110 octane, leaded, Torqo race fuel. Not much power increase if any, but WAY smoother running.
  • Virge
    by Virge » Thu Oct 27, 2005 8:34 pm
    05 450x 800 ft elevation
    White Bros smog eliminator kit
    Applied crank case re-routing kit
    Twin Air power flow kit
    Stock exhaust baffle removed
    Air box mod per Honda Closed Course racing only doc Includes side airbox hole cut.
    JD jet kit - 170 main and red needle jet with clip in middle.
    CRFSonly fuel screw, set to 1 1/8 turns
    Napalm racing air filter screw.
    Just finished tonight, it took a while to start but maybe because of lack of fuel. Cold to start but once warm it rails like no other.
    I might try tomorrow to reset the fuel screw in conjunction with the idle screw, I feel it may not be out enough.
    Gas,Gas,Gas till you see God, then brake!
    05crf450x
    78 xr75 (Daughters)
    04 crf150(Sons)
    01 100' prostreet(Nice Chop)
    by [email protected] » Thu Oct 27, 2005 8:39 pm
    Virge, with the top AND sides cut, especially like Honda has you do it, you're gettin a little more air than we are. Try 1 and 1/4 out on the fuel screw, that may fix the cold to start thing. Let me know how that goes. Doug
Post Reply 92 posts
