CRF150R AFTERBURN
  • Speedshifter
    CRF150R AFTERBURN
    by Speedshifter » Sat Mar 07, 2009 4:57 am
    I PUT A SIZE 45 PILOT IN ALONG WITH THE OTHER RECOMMENDED 138 MAIN SIZE 9 PLUG ECT. TRYING AP MOD TODAY. ENGINE PULLS HARD AT WOT. WON'T IDLE RIGHT WITH POPPING. IS IT POSSIBLE TO NEED A MUCH LARGER PILOT LIKE A 50 OR 55?
    by Asmith » Sat Mar 07, 2009 6:46 am
    No. Try opening up the fuel screw a bit.
  • Speedshifter
    by Speedshifter » Sat Mar 07, 2009 2:16 pm
    ~ wrote:No. Try opening up the fuel screw a bit.
    Tried it up to 3 turns no change. No air intake leaks. All new head work. Throttle position sensor tested good. I run 50/50 race gas and a 13 2 1 piston. The bike has done this since new. Trying larger pilots. If that's not it. Must be ignition. Any more suggestions is greatly appreciated. Thanks Agent
