Poor Throttle response
  • dom
    by dom » Mon Sep 12, 2005 10:37 am
    I bought my wife a 05 CRF100 in the spring. The bike gets used alot by the whole family. It seems to have lost its quick throttle response. When you snap the throttle there is a little lag before it takes off. What is the problem ? Should I be changing the plug and checking the valve gap already ? If I need to check the valve gap do I need any special tools from honda ? The book shows one but I am unsure if it is really neccessary.
    Thanks
    motokid54
    by motokid54 » Mon Sep 12, 2005 3:12 pm
    Do you clean your air filter often if not try that. You could also cheak your twist grip when the bike is off slightly twist the throttle if there is alot of play (loose twisting with no friction ) then all you need to do is tighten the throttle cable by the ajuster on the throttle assembly if there is not enough room them you will need to do it on the carburator end
    '04 crf 150, msr dominator bars, cyrca stealth hand shields, renthaul full dimond grips, new tires, Twin air dual stage air filter, FMF power core 4 exhaust, uncorked air box, 13,50 gearing,non-o-ring competition chain, ebc brake shoes
  • dom
    by dom » Tue Sep 13, 2005 6:15 am
    Thanks.........I will give that a try this weekend. Funny one of my friends said the throttle did not feel right.
    About how many hours does the bike have to have on it before I need to worry about the valves needing adjustment ?
    PGer555
    by PGer555 » Tue Sep 13, 2005 12:05 pm
    i havent even check mine on my 230 and its been like a year.
  • willflyforfood
    by willflyforfood » Tue Sep 13, 2005 11:52 pm
    PGer555 wrote:i havent even check mine on my 230 and its been like a year.
    Are you serious?? The manual says every 600 miles(1000 kms). I clean my air filter when I change my oil, 5-8 rides, which is a little bit less than the recommended(about 550-650 kms).
    PGer555
    by PGer555 » Wed Sep 14, 2005 11:53 am
    The bike runs great but i think ill get them checked out this winter
    motokid54
    by motokid54 » Wed Sep 14, 2005 4:12 pm
    are you serious :?: that can do almost as much dammage as not checking your valves I clean mine every time I ride and it only takes about two hours in dusty/sandy conditions to turn your filter black if it is to hard to pull air through the filter it will go around it. Past what used to be the "sealed" ring of the filter sending all of that unwanted dirt through the carb. and into the cylindar tearing up the ring
    Point:
    Cost of 1/4 gallon of gas $.87 oil $1.14 engine and carburaor work :evil: more years out of your bike priceless :roll:
    afc1261
    by afc1261 » Mon Oct 03, 2005 7:21 am
    my wifes stock 100 has been running terrible.....ie poor throttle response...... I checked the fuel mixture screw on the bottom of the carb and it was out 2 1/2 turns. I set it a 2 turns and it runs much better. Is this the common setting for a bike below 1000' sea level?
