cr 85 springs on a 150f
  • would you put cr85 forks on your 150f?
    yes
    8
    100%
    no
    0
    No votes
    Total votes: 8
  • wildman2393
    by wildman2393 » Sat Jan 10, 2009 6:19 pm
    I was interested in using my friends cr 85 forks and using them on my bike, is there anything i should know about before i get them them them, do i need new triple clamps? if i do can i use the old cr 85 triple clamps? can i take the spring from the cr85 too? thanks
  • CRF916
    by CRF916 » Sat Jan 10, 2009 7:01 pm
    I would jump all over it! 8)
    0'6 CRF450XXX
    by Asmith » Sat Jan 10, 2009 7:07 pm
    You can use the lower part of the triple but not the top. You'll need an adapter for the brake caliper, spacers and an axle from a CR 85, new fork stops, and a bracket to relocate the ICM.
    The steering stem will need to be modified as well.
    REGER Engineering has everything for the conversion.
    mikey526
    by mikey526 » Sat Jan 10, 2009 8:01 pm
    Why would you do this, the 150R has bigger cannons than the 85's... :?
    by Asmith » Sat Jan 10, 2009 10:46 pm
    mikey526 wrote:Why would you do this, the 150R has bigger cannons than the 85's... :?
    Same forks between the 150R and the 85's.
    BTW he wants to do it to a 150F.
  • MiniMe1969
    by MiniMe1969 » Wed Feb 25, 2009 5:07 pm
    I just finished the CR85 fork conversion on my 150F. I used the kit from Reger Engineering, which was spot on and was very easy to install. Found the forks on Ebay for a great price so I saved a little there.
    Looks killer, and I can't wait until the ground thaws to conduct testing. Combined with a Works rear shock it should work out great!
