Race worthy 150
    motokid54
    Race worthy 150
    by motokid54 » Fri Sep 02, 2005 6:49 am
    I was wondering how many people race theyre 150s and what class they race in. here in division 3 150s have to race 125 schoolboy or 125 amateur wich is not hardly fair I think the 150 should race with the 85s the four stroke cut off for the 85 class is 125cc and for those of you who race how competive is your 150 in your class. thanks
    '04 crf 150, msr dominator bars, cyrca stealth hand shields, renthaul full dimond grips, new tires, Twin air dual stage air filter, FMF power core 4 exhaust, uncorked air box, 13,50 gearing,non-o-ring competition chain, ebc brake shoes
  • Joker7Icp
    by Joker7Icp » Fri Sep 02, 2005 6:10 pm
    Yea wow I was thinking that yesterday... Me to 85 sounds right!
    I got a CRF 150
    motokid54
    by motokid54 » Mon Sep 12, 2005 4:45 pm
    any one else... please
  • CRFrider04
    by CRFrider04 » Tue Sep 13, 2005 5:37 am
    Im from mass and around here we race 150's with two stroke 85's. The 150's usually get killed unless you've for a bunch of aftermarket performance parts on them. A 150 needs at least a pipe, filter and revbox to keep up with a stock cr85.
    ________________________________________________
    04 CRF150, BBR springs, Uncorked airbox, No baffle
    PGer555
    by PGer555 » Tue Sep 13, 2005 12:07 pm
    the 150's suspension is no where near as good as the 85 either
  • dan256
    by dan256 » Wed Sep 14, 2005 7:05 pm
    In california we race our 150s with the 85's and a special 4 stroke class. Me and my 150 won both championships.
    crf 150 175kit, big gun exhaust, rev box, jets, tj graphics, high flow air filter, air box unplugged.
  • CRFrider04
    by CRFrider04 » Thu Sep 15, 2005 5:29 am
    Dan do you have any suspension mods? i cant immagine racing with the stock suspension.
    Crf150, BBR springs, Uncorked airbox, no baffle
  • dan256
    by dan256 » Sat Sep 17, 2005 8:28 pm
    yea i got the bbr stiffer springs
    motokid54
    by motokid54 » Sun Sep 18, 2005 2:31 pm
    thanks for info guys hay is a 175 leagal in 85class what are you displacement limits and what ama division are you in
  • CrazyRF150
    by CrazyRF150 » Tue Sep 27, 2005 10:03 am
    Has anyone tried using just one BBR spring with one stock? I put the two BBR springs on a CRF100 a while back and it made it too stiff for me (140 lbs) and top out BAD. I realized there were no amount of mods that I could do to a 100 to make it worthwhile so I got the 05 CRF 150. Now I'd like to improve the suspension for a little racing but don't want to have the same experience of making the front TOO stiff. I've heard that you can try one BBR one stock and that works well. Curious what experience has been for others...
    Some guys just add a few washers in the bottom of the forks to increase the preload on the springs and run 15wt oil and say that is a good alternative to the BBRs... Anyone doing that?
    P.S. Takes a lot to make these 150s competitive with the 85s. The CR85 has more HP, far superior suspension and weighs 60lbs less! I can't imagine a crf150 being competitive with 125 2-strokes no matter what the mods! (that why 250f's compete with 125s!)
    05 CRF150
    BBR Exhaust
    Renthal Drivetrain
    Dunlop D756 rubber
    PGer555
    by PGer555 » Tue Sep 27, 2005 12:10 pm
    Whats a 40 year old like you messing around with xr100s and crf150s. shouldnt you have a 250???450???
  • CRFrider04
    by CRFrider04 » Wed Sep 28, 2005 5:44 am
    At 140 pounds you should put both BBR springs in and use 10 wt fork oil. I weigh 130 and ride pretty agressive...it works fine for me...sometimes not stiff enough tho
  • crankshaft
    by crankshaft » Mon Oct 10, 2005 12:23 pm
    I have raced mine on a home made track about once a week. 150's work fine but you haft to watch your saspention becuase you bottom out alot.
    2004 CRF150
    kenda southwick front tire
    Michalin M2R rear tire
    D.I.D chain
    909 bars
Users browsing this forum: No registered users and 12 guests
