help 03 crf 230f
  • crf230er
    help 03 crf 230f
    by crf230er » Wed Oct 15, 2008 5:03 pm
    :?: hey so im new but anyways heres my story
    i went rideing today and my bike was burning oil pretty good well it stalled and i couldnt get it running... it still doesnt run i checked the gas which was full i checked the oil that was full checked the spark plug and replaced it and it isnt gettingt any spark so can any one help me out
    by Old Dude » Wed Oct 15, 2008 5:56 pm
    crf230er
    Is the plug oil fouled? (black and oily) Do you have no spark at the plug or at the plug wire cap? Change plug. Check electrical connections. If its burning oil it may need a new top end. Good luck!
    amaviper
    by amaviper » Wed Oct 15, 2008 6:15 pm
      Faulty spark plug
      Fouled spark plug
      Loose or disconnected ignition system wires
      Faulty ignition coil
      Faulty igniting pulse generator
      Faulty exciter coil
      Faulty ignition switch
      Faulty engine stop switch
      Faulty ignition control module (ICM)
  • crf230er
    by crf230er » Wed Oct 15, 2008 7:19 pm
    i changed the plugs its not getting any spark tho
    my friend think i could have blown the motor but i dont think so
    amaviper
    by amaviper » Thu Oct 16, 2008 10:07 am
    You are too vague to even attempt to help.
    What year?
    How many hours on bike?
    What color of smoke? Blue or Black?
    Have good compression?
    What was the last thing you did to it?
    How do you know it doesn't have spark? Because it doesn't start or? Did you pull the plug - put the spark plug cap back on and turn the motor over while touching it to the head to see if there was in fact a spark? (don't shock yourself) Try this with more than one spark plug?
    Electric starter does turn it over - correct?
    Have you looked at your air filter?
    Checked the wires at the coil to see if they are attached correctly?
    Plug wet from gas?
    etc etc
  • crf230er
    by crf230er » Thu Oct 16, 2008 10:28 am
    an 03 crf230f doent have a kick start for the first thing the last thing i did to it was painted the front brake and rear sprocket
    amaviper
    by amaviper » Thu Oct 16, 2008 3:18 pm
    You obviously have a handle on it. Edited out the (when you kick it over) after "Does it have compression" for you.
    Good Luck
  • crf230er
    by crf230er » Thu Oct 16, 2008 6:27 pm
    yes it has compression it just isnt sending any spark to the plug
