viper1891 wrote:i have a 2004 crf250r that i just recently bought. when i got the bike the owner before me just put on new rear brake pads...well the brakes weren't working that good so i went to bleed them and when i did i never got it to work again. a little bit of fluid comes out but it doesn't build pressure. whats going on?? any help would be greatly appreciated! thanks!
Monkeywrench wrote:viper1891 wrote:i have a 2004 crf250r that i just recently bought. when i got the bike the owner before me just put on new rear brake pads...well the brakes weren't working that good so i went to bleed them and when i did i never got it to work again. a little bit of fluid comes out but it doesn't build pressure. whats going on?? any help would be greatly appreciated! thanks!
Sounds like you may have a good bit of air in there.
Try this:
1) Make sure you have enough brake fluid. Add if needed.
2) Pump up the rear brake pedal to ensure you can at least build some kind of pressure.
3) Have an assistant hold the brake pedal down while you crack the bleeder valve. Tighten the bleeder valve after the pedal has dropped *before* your assistant takes his foot off it.
4) Recheck fluid amount. Add if needed, and repeat 2+3.
See if that helps - would be hard to imagine you have a faulty master cylinder, although it's not impossible. If the caliper is at fault, I'd think you'd see leaking fluid from somewhere.
What does the pedal feel like right now?
