Snapped front fork air pressure release screw
  • chris holm
    by chris holm » Tue Sep 23, 2008 10:22 am
    My mechanically inclined son decided to let the air pressure out between motos and when tightening the screw back in it snapped off - 1/2 still inside. Anyone know an "easy" way to remove it? CRF150R
    Thanks
    by 124 » Tue Sep 23, 2008 10:39 am
    An "easy out" should do the trick...
    Or screw extractor found anywhere, Craftsman shown here:
    http://www.sears.com/shc/s/search_10153 ... s&sLevel=0
    by bocephus450x » Tue Sep 23, 2008 11:37 am
    minton227
    by minton227 » Fri Dec 05, 2008 12:48 pm
    Once you have the screw out, I would recommend a set of fork bleeders from Motion Pro. I just added them to my bike for under $20. They replace the factory screw with a valve. You can then just push the button on top of the valve to release the air any time with no tools.
    minton227
    by minton227 » Tue Dec 30, 2008 6:19 am
    Well, the Motion Pro fork bleeders are junk. They are made of plastic and both broke off in the forks while I was installing them finger tight. I got my money back and got some from Anderson Automatics. They are made of metal and are a lot smaller for better bar clearance. They claim to be the only ones made of metal, not plastic. I would definately recommend these.
  • fast4fun
    by fast4fun » Wed May 06, 2009 6:38 pm
    STR Speed bleeders. Installed them a couple months ago and their high quality. Short, made of metal, and easy to install.
    http://www.crfsonly.com/catalog/product ... ts_id/1372
  • jjrace
    by jjrace » Wed May 06, 2009 8:46 pm
    motion pro bleeders are garbage! JUNK JUNK JUNK
    Best bleeders are the Anderson:
    http://www.andersonautomatics.com/bleeders.html
    They are shorter than the STR ones and dont take a special tool to install. Just simple 8mm deep socket.
    #861
    '05 crf450r
