2007 crf250x jetting
  • 831sc
    by 831sc » Mon Aug 18, 2008 6:04 pm
    hi i just got my fmf ti powercore on my 2007 crf250x
    i was wondering what kind of jets i should put in it? i ride at sea level too 2500 feet.
    thanks nick
    by Asmith » Mon Aug 18, 2008 6:47 pm
    JD Jetting Kit.
    http://www.crfsonly.com/catalog/product ... ts_id/1096
    Red needle 5th clip, 162 main jet. Open up the intake with a Twin Air filter and lose the backfire screen.
  • 831sc
    by 831sc » Tue Aug 19, 2008 7:53 am
    what is the red needle. and is the stock needle jet adjustable? when you say 5th clip do you mean from the bottom or the top. and where can i buy the red needle?
  • corey_lax
    by corey_lax » Wed Aug 20, 2008 6:36 pm
    when you buy the JD kit it comes with numerous pilot and mains.. and a blue needle and a red needle. for your elevation and temp you use the red needle. The clip is on the 5th from the top. I think all the jd kits come with it on that position.
    The jd kit is definatly worth buying to get the needle and the assortment of jets. This way if you travel somewhere you can easily switch your jets. its well worth the money.
  • corey_lax
    by corey_lax » Wed Aug 20, 2008 6:38 pm
    o ya... and while you are working on the carb... you should switch the fuel screw to a CRF only fuel screw...
