Need some help with high siding.
    djh65
    by djh65 » Sun Jul 13, 2008 8:43 am
    So last year my son and I were riding on a lake bed. It was really slick and muddy. I was working on my sliding but found when I got around too far the back tire would catch and launch me. This was no big deal as we were riding on mud. So 3 weeks ago I was on a blue groove fire trail. Coming about a turn about 20 mph and the back tire started sliding. I did my best to steer into it with no luck. I got a quick trip to the ground with a torn ligament in my ring finger and a pretty bad concussion. Anyways my question is this. What do you do when the back end gets too far around?
    Thanks,
    David
    06 HD450X made in america.
  • ThumperX
    by ThumperX » Sun Jul 13, 2008 11:39 am
    Clutch it.
    05' CRF250X
    07' CR250R
    02' CRF450R
    Just me
    by Just me » Sun Jul 13, 2008 12:51 pm
    Stop the swing before you get to full lock or you are going down. Roll out of the throttle or clutch in.
    Use only Genuine Interocitor Parts.06 250X Flatlands skid and rad guards. Clarke 3.1 gal tank. Cycra Probends, Rekluse Pro, correct springs. Horn, mirror, brake/tail/license lights and a hanger for the plate. That is all.
    djh65
    by djh65 » Sun Jul 13, 2008 1:41 pm
    it came around so fast. I got off it but it kept sliding.
  • ThumperX
    by ThumperX » Thu Jul 17, 2008 5:23 pm
    At that point all you can really do is tap the rear brake if possible otherwise your getting dirty.
    05' CRF250X
    07' CR250R
    02' CRF450R
  • topgun
    by topgun » Thu Jul 17, 2008 8:01 pm
    Depending on speed and terrain I would be leaning it over more to counteract possible highside and steer with the throttle
    Failing that try strightening the bars - sounds weird but if you can get the front wheel going sideways a bit as well then no high side but you need a bit of room as you will be in a semi controlled sideways drift
    djh65
    by djh65 » Thu Jul 17, 2008 8:56 pm
    after giving it lots of thought the skid mark was only about 10 feet. The time to make some sort of correction was not really there. It was slide slap. Oh well
    by crfsonly » Thu Jul 17, 2008 10:49 pm
    wish i could help you...but high-siding is how i shattered my tail bone...so i would only be able to help you high-side in spectacular form!
    djh65
    by djh65 » Fri Jul 18, 2008 8:31 pm
    My girl friend she said she wished I had my helmet cam on it would have been a mountain of plastic bits but the card would have showed it all. Geee thanks. lol
    David
  • Trogdor
    by Trogdor » Sat Jul 19, 2008 8:27 am
    topgun wrote:Depending on speed and terrain I would be leaning it over more to counteract possible highside and steer with the throttle
    BINGO!!! We have a winner!!! Here's a pic of Gene Romero showing proper execution of the technique:
    woodsman
    by woodsman » Sat Jul 19, 2008 8:29 pm
    I'm still trying to learn how to throw around a 450, but I'm learning on a little xr100 in a very dusty flat track. Try a smaller bike that you can control no matter what. I can break the rear wheel lose on that thing in 4 gear, and its geared pretty tall. It was really scary the first few times, but that pic above is dead on. Try sliding in sand also. ;)
    Currently, 05 450X
    by crfsonly » Sat Jul 19, 2008 9:00 pm
    here's a tip...it's less painful to lay it down than to high-side. so, keep the bike low and throttle control is critical...if you get into the throttle too fast or hard the back end will come around and then it's over.
  • WFOWOODS450
    by WFOWOODS450 » Sun Jul 27, 2008 3:19 pm
    wanna stop high siding? stop quickly closing the throttle!!! if u stay in the gas and even give it more the tire will lose traction and the bike cant high side. Worse comes to worse u low side and get back up. your biggest mistake is getting out of the throttle, the bike is immediately going to hook up and launch u like a rag doll.
