seized engine help!
    ship_killer6666
    seized engine help!
    by ship_killer6666 » Sat Jul 12, 2008 2:31 pm
    My rm125 05 ran very well for 20/30 min. then all of suddent engine died like if the spark plug was gone, kickstarter can't be moved by a Millimeter, My engine is seized, some people said it is badluck, other said it is because the bike was too lean (didn't need chocke to start it), some say "sand" but my air filter is alright
    what might be to replace? cylinder? piston? crank? cranks bearing?
    mustang
    by mustang » Sat Jul 12, 2008 2:38 pm
    you can seize a 2 stroke pretty easy by overheating it actually .
    when it cooled off can u kick it over ?
    You might want to up the oil mix a little bit , when people told you it was lean they didn't mean your jetting they meant the oil mixture in your pre mix
    c-ya****mustang Image
    ship_killer6666
    by ship_killer6666 » Sat Jul 12, 2008 2:56 pm
    nope, 30:1 like service manual, they told about jetting too lean because I could start and run the bike without the choke
    woodsman
    by woodsman » Sat Jul 12, 2008 3:52 pm
    Thats not too lean... My cousin runs 42:1. Does it have oil in it? What color is it?
    Currently, 05 450X
  • redrooster65
    by redrooster65 » Sun Jul 13, 2008 8:06 am
    Lean has more to do with the jetting then the mix.
    Did you ever do a plug read?
    2-strokes can be prone to heat seizure if you run them too hard before they are at operating temp. Once you tear it down you will know what happened.
    Ride Red :P
    ship_killer6666
    by ship_killer6666 » Sun Jul 13, 2008 9:45 am
    Mhhh, strange, Because I started it without choke (that's why I think the jetting is too lean). let it ran 2-3 seconde on idle, then I twist the throttle a little bit, I did that a complete minute before going on the track. Was it the best way to warm it?
    edit: also I can move the kickstart today, I didn't tried to make the bike start, just wanted to see if my crankshaft was OK. I don't care to put a new piston in (I already have a wiseco with rings and gasket kit) I don't want to have to change my cylinder and/or my crankshaft bearing (someone told me rm125 05 are prone to have loose crankshaft bearing)
    Just me
    by Just me » Sun Jul 13, 2008 12:58 pm
    If it starts without the choke and it is cold out, it isn't too lean. It's rich. A choke (Or enrichener) adds fuel during start up. If you can start with out that additional fuel, you aren't lean.
    If you go gas assin' before the engine is fully warmed up, you can cold sieze the engine. If it is over rich, it will take longer to get up to temperature. You need to do plug chops and read your plugs whenever you change alltitude, temperature or oil type/mixture and or carb settings.
    Use only Genuine Interocitor Parts.06 250X Flatlands skid and rad guards. Clarke 3.1 gal tank. Cycra Probends, Rekluse Pro, correct springs. Horn, mirror, brake/tail/license lights and a hanger for the plate. That is all.
    ship_killer6666
    by ship_killer6666 » Sun Jul 13, 2008 2:18 pm
    First of all I'm going to find someone near my city who rebuild 2 stroke dirt bike often, then I'm going to bring the part and my eyes to see how to do a top-end and how to adjust my jetting
    but what happened is that it cold seized?
    because It had time to warm up, 1, 1,5 minutes before going on the track and then 20-25 minutes riding hard on the track, it would have seized before
    ship_killer6666
    by ship_killer6666 » Sun Jul 20, 2008 10:30 am
    Sand was sucked into engine
    air filter was not installed properly
    goddamnit
