Sand suspension adjustments
  • parkerfly
    by parkerfly » Fri Jul 11, 2008 9:02 am
    Going to the sand dunes this wknd. I've never ridden in sand, right now my bike (450R) is setup for trail riding. Should I adjust my compression/rebound for riding in the sand?
    I've heard set the front hard and rear soft and it will make a big difference. Does that sound right... Also is that talking about compression, rebound, or both?
    by Asmith » Fri Jul 11, 2008 9:26 am
    Compression.
  • parkerfly
    by parkerfly » Thu Jul 17, 2008 12:19 pm
    I set the compression in the front to almost full hard and the compression in the rear to almost full soft. Left the rebound alone.
    Made a huge difference in the sand, much more stable. So stable in fact I forgot to lower the air pressure in my tires which is also supposed to help.
  • jt1872001
    by jt1872001 » Thu Jul 17, 2008 10:50 pm
    I set the compression stiff. pretty much the same setting as track riding. And a paddle tire .
