05 450x Jetting
    oldschoolmalibu
    05 450x Jetting
    by oldschoolmalibu » Mon Jun 30, 2008 2:49 pm
    O5 450x. Procircuit Ti4 Silencer and Header, Air box sides and snorkel cut, Twin Air filter, QS2 Accelerator pump cover, Devol radiator guards, and I am at sea level. What pilot, main jet, leak jet, needle, and clip position do you guys suggest. Performance is great, it fries all the time. Using JD Jet kit. I think it has a 165 main jet, don't know anything else. Need suggestions so i know where to start. Thanks
    by Asmith » Mon Jun 30, 2008 4:16 pm
    JD red needle 4th clip, 170 main, fuel screw opened to 2 turns out.
    by Skoot22 » Mon Jun 30, 2008 5:18 pm
    ~ wrote:JD red needle 4th clip, 170 main, fuel screw opened to 2 turns out.
    Agreed.
    Also make sure you run a full quart in the transmission.
    oldschoolmalibu
    by oldschoolmalibu » Tue Jul 01, 2008 8:51 am
    Thats what I was thinking. I will try that since everyone has told me thats the right setting. That should cure it. Thanks for the help. I will let you know what the results are. I just started running a full quart of oil in the tranny. Thanks for the tips guys.
    by bocephus450x » Tue Jul 01, 2008 10:25 am
    doesn't this set-up call for a 48 pilot??
    by JAWS » Tue Jul 01, 2008 10:49 am
    bocephus450x wrote:doesn't this set-up call for a 48 pilot??
    It doesn't necessarily call for one. This is very machine dependent. Mine runs well with the 48, as do others, but many will do better with the stock pilot.
    by bocephus450x » Tue Jul 01, 2008 10:52 am
    wait....you mean its not an exact science?? :shock:
    RLPII
    by RLPII » Tue Jul 01, 2008 12:16 pm
    Really, why? :-k
    Oh, and how do you do a specific quote where the posting actually shows who you are quoting?
    Bob
    ~The way I ride no need to worry about cholesterol~
    2005 CRF 450 X
    by bocephus450x » Tue Jul 01, 2008 12:25 pm
    Really, why? :-k
    hit the "quote button" in the top right hand corner of the post you want to quote.
    run a full qt in 2005-2006's becuase there have been reports of there being a lack of lubricationin these years. Its really only a porblem oo dual-sported bikes that run wide open on flat ground for extended periods of time. its cheap insurance
    RLPII
    by RLPII » Tue Jul 01, 2008 12:32 pm
    bocephus450x wrote:
    Really, why? :-k
    Roger That and thanks for the info! :D
    Bob
    2005 CRF 450 X
