2007 CRF 150 jetting
  • CRF150mom
    by CRF150mom » Mon Jun 02, 2008 12:25 pm
    I'm looking for advice with the jetting of my son's 2007 Honda CRF 150R. Any suggestion on what size jetting is needed for improved performance? It's currently stock. Thank You
    by Asmith » Mon Jun 02, 2008 1:42 pm
    The stock needle is on the 3rd clip. Stock pilot is a 40. Stock main is a 135.
    The cure for the hard start is both jetting and procedure.
    Change the set up to:
    138 main, 45 pilot, 40 leak jet, o-ring on AP linkage, grind rivet flush, fuel screw at 2 turns out.
    Use this starting procedure: fuel on, choke on, 3 good twists of throttle,
    1 or 2 kicks it will fire up.
  • CRF150mom
    by CRF150mom » Mon Jun 02, 2008 3:34 pm
    ~ wrote:The stock needle is on the 3rd clip. Stock pilot is a 40. Stock main is a 135.
    Thank you for the advice ~. I guess I shouldv'e looked around more as I did find other threads relating to this topic. I am hoping this will help the flattening out problem, meaning it just seems to lose power quickly in each gear. If that makes any sense. I really appreciate your advice. Hope to do this tomorrow. We don't have too much of a problem with starting, on occasion when it is warm though. Thanks again, any other advice on modifications you know of would be great!
  • Collin
    by Collin » Mon Aug 11, 2008 9:33 pm
    This is great info, but what is the rivet grind thing all about?
    Zanardi4
    by Zanardi4 » Sun Mar 22, 2009 6:49 pm
    Agent,
    Would this also be the setup for Cal City/Randsburg? (2600 - 3000 ft alt)
    Thanks Paul!
    Joe V
    Joe V. - Simi Valley, CA
    amaviper
    by amaviper » Sun Mar 22, 2009 7:02 pm
    Collin wrote:This is great info, but what is the rivet grind thing all about?
    Red Beards AP mod. Rivet is on the diaphram. Look on page 14 of below link.
    http://www.squadpage.com/pandora/Professor%20RedBeard450%20How-To%20AP%20Mod.pdf
    by Asmith » Sun Mar 22, 2009 7:09 pm
    Yup. It'll work perfect up there.
    Agent,
    Thanks Paul!
    Joe V
    Zanardi4
    by Zanardi4 » Mon Mar 23, 2009 10:37 pm
    Thanks Paul! 8)
    Agent,
    Joe V
    Thanks Paul! 8)
