deacceleration popping
  • crfgal218
    by crfgal218 » Mon Apr 28, 2008 10:02 am
    Hi, my crf has been sitting for about 6 months with no fuel in the carb or tank. I added 2 teeth to the rear sprocket and took it out this weekend. I had a LOT of popping going on everytime the bike deaccelerated. What is that all about, never happened before. Is it because the bike sat? Would the gearing do this? Should I adjust the fuel screw out a half or quarter turn? Thanks for the help, Nancy
    by Asmith » Mon Apr 28, 2008 10:09 am
    Try the fuel screw to see if that makes a difference. If not, the pilot jet may be partially plugged.
    The gearing would have no effect.
    by Skoot22 » Mon Apr 28, 2008 11:22 am
    ~ wrote:Try the fuel screw to see if that makes a difference. If not, the pilot jet may be partially plugged.
    Agreed
    laker
    by laker » Fri Aug 15, 2008 10:22 pm
    mine did the same thing and turning the fuel screw fixed the problem
    Team NoFrills
  • lemooreace
    by lemooreace » Fri May 01, 2009 4:38 pm
    Sometimes all you need is a new head pipe seal. Cold air entering will cause popping.
