Jetting an 06 250x with Powerbomb Header and FMF pipe
    by [email protected] » Thu Apr 17, 2008 12:02 pm
    Hi all. I bought a used 2006 250x a few months ago and it came with a Powerbomb header and an FMF Q2 pipe. It was rejetted as:
    Main: 152
    Pilot: 42
    Leak: 70
    Needle: NCYS (different than stock NCVT)
    Clip: 4th position
    Pilot Screw: 2 1/4 turns out
    It also has a quickshot 2 installed and the bike seems to run pretty good (no bog, good acceleration, etc.). However, I don't really have anything to compare it to and wonder if I can get more out of it by rejetting based upon what I've read on this sight. I thought about just installing a JD jet kit but I don't want to go through the time/cost if it won't improve much over what I have now. What do you think?
    Thanks!
    P.S. I've also cut out the airbox and removed the backfire screen.
    by [email protected] » Tue Apr 22, 2008 1:53 pm
    Hi all. Any ideas on whether I should rejet?
    NCFRC
    by NCFRC » Sat May 24, 2008 3:05 pm
    Alot depends on your elevation and everyones bike is slightly different,, but these are my suggestions to try or maybe just compare to my trial and error.
    I personnally don't like the #70 leak jet , use a #55 which I believe is stock. With a smaller leak you'll get more fuel out of your accelerator pump for better response.
    If the exhaust and intake are really uncorked , not just slightly, you may find you want to go up on your jetting.
    My 04 / 250X with stk header and FMF rear slip-on, Pink wire mod , stk cam is running these settings.
    Slow jet - 45
    Main jet - 155
    Leak jet - 55
    Needle clip - 3rd down
    fuel/air screw - 2 turns out
    I run 93 octane pump fuel,,,,, we'll talk additives another time as I'm in the Industrial chemical business.
    Elevation - 700' ft above sea level.
    No bog , No cough "girgle" , runs very strong !
    NCFRC
    by NCFRC » Sun May 25, 2008 6:24 am
    YES , the air box has been modified also.
    by [email protected] » Sun May 25, 2008 7:28 pm
    Thanks - I'm at about 200-300 ft. I'm not sure why they replaced the leak jet and made it so large. I've got the stock leak jet that I can reinstall. Do you think installing the JD jet kit with the red needle would be helpful?
    NCFRC
    by NCFRC » Tue May 27, 2008 4:17 pm
    In the Honda Closed Course Competition settings chart that Honda published , it showed installing the #70 leak Jet. Alot were replaced without realy knowing what it did and some assumed the bigger the better.
    Most have found the stock #55 works the best.
    Even the 2008 CRF250R works far better with a 55 than the 70 thats stock.
    I'm amazed at the people running a 160-165 main jet,,,,, I havn't tryed it so I have no comment besides if you ride at 10,000 plus rpm's most of the time , then I can see where it would work good.
