Jetting for 08 CRF250X
  • Ben
    by Ben » Mon Apr 14, 2008 11:56 pm
    Hi everyone, I want to do the airbox mods and uncork the exhaust as per many posts, I have ordered the JD Jetting kit, but will take a couple of weeks to be shipped here, does anyone have any guidelines on what stock jet sizes to use until my kit arrives?
    I ride at approx 6000ft bout 70F and occasionaly ride at sea level.
    Awesome site, lots of usefull info.
    Thanks
    Ben
  • lance_m
    by lance_m » Sat Apr 26, 2008 12:28 pm
    Hi Ben, I'm in the same boat as you almost.
    Just bought an '08 250x, and I run it mainly around sea level and from 40 - 70F.
    I'm doing the airbox cutout, air filter screen, and drilling the exhaust. Then rejetting with a JD kit.
    The instructions say red needle, 5th clip, and 160 - 165 main jet. Pilot doesn't need changing on '07s and '08s apparently.
    Let me know how you get on, and I'll keep you posted.
    Lance
  • redrooster65
    by redrooster65 » Sat Apr 26, 2008 12:46 pm
    I would go with the 155 main 42 pilot and red on the 4th.
    With the 150 it is perfect at my normal riding area but I am afraid it would be too lean the few times I ride at lower elevations, It ran good at both with the 155
    Runs crisp with o bog.
    Year: 2004
    Elevation: 4,000 - 9,000
    Temperature Range: 50 - 100
    Smog (AIS): No
    Airbox Modified Top: Yes
    Airbox Modified Sides: No
    Backfire Screen: Yes
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 155 now 150
    Needle: Red
    Needle Clip Position: 4th
    Fuel Screw Type: CRF's Only
    Fuel Screw Setting: 1 3/4 now 1 1/2
    AP Modified: No
    Leak Jet: 55
    AP Cover: No
    Exhaust Type: Stock
    Exhaust Modified: Drilled
    Pink Wire Modified: Yes
    NCFRC
    by NCFRC » Sat May 24, 2008 3:48 pm
    If you look at other 250X posts on here, you'll find some very similar suggestions.
