15 tooth
  • chillyengineer
    15 tooth
    by chillyengineer » Tue Apr 01, 2008 2:48 pm
    Just fitted a 15 tooth front sprocket,not much room between teeth and swing arm rubber or sprocket cover but hey does it transform that gear box!! :lol: :lol: ,anyone got a great way of removing the scratches from plastics??either polishing out or what ever :?
    gal8x
    by gal8x » Tue Apr 01, 2008 4:29 pm
    I refurbished my plastics on my 450 before painting them black. I used 220 and 400 grit to remove scratches, and 1500 (use water) after each coat until the last coat which just got a coat of wax.
    Now if you want to renew stock plastic then fallow the same coarse but don’t paint. To get the shine back you will need an angle grinder with a polishing wheel (remove the wheel guard), a bench grinder is normaly used but the maneuverability too limited. You will find rouge hanging near the polishing wheel (at the store), get one that works with plastic.
    Start the grinder, apply the rouge to the spinning wheel then use the wheel on your sanded plastics. Stop often so you don’t build up heat.
    2005 CRF450X (plated)
  • chillyengineer
    by chillyengineer » Wed Apr 02, 2008 8:52 am
    Thanks Gal ,good info ill try it :D
